'96 Bronco steering column bearings - Ford Truck Enthusiasts Forums
Old 01-23-2011, 02:12 PM
tim189 tim189 is offline
tim189 is starting off with a positive reputation.
Can someone please explain how to replace the steering column bearings in a 1996 Ford Bronco (tilt wheel, air bag)? I've got it down to the cast aluminum housing but can't figure out how to the get to the bearings. Every book I've looked at doesn't give a diagram, pictures or instructions they only say to take it to the dealer. I hope someone can help my out.
p.s., this is my first post here and hope I'm in the right place to post a question. Thanks in advance for your help.
Old 01-23-2011, 02:34 PM
greystreak92's Avatar
greystreak92 greystreak92 is offline
greystreak92 has a great reputation on FTE.greystreak92 has a great reputation on FTE.greystreak92 has a great reputation on FTE.greystreak92 has a great reputation on FTE.greystreak92 has a great reputation on FTE.
You are in the right place... Welcome. Alas, I don't have the answer you seek but someone here does. They'll be along soon.
Old 01-23-2011, 02:39 PM
Thanks greystreak92, appreciate your quick response and hopefully someone else will be just as quick.
Old 01-23-2011, 10:42 PM
KC92F150 KC92F150 is offline
KC92F150 is starting off with a positive reputation.
tim189,
First of all, Welcome to FTE
I had to replace my bearing as well, mine is a 97 F350 but I think the columns are the same. Keep in mind though, I DO NOT have an air bag, so I am not sure how to remove that.
Check out this link, I hope it helps:
http://www.ford-trucks.com/forums/10...ng-column.html
Good luck
Old 01-24-2011, 06:56 AM
Encho's Avatar
Encho Encho is offline
The Southernmost Mod
Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.
That is the main issue, the airbags, if you have them, it's rather dangerous if you don't do it right, as if the airbag deploys it will seriously injure you. I remember someone mentioned you have to disconnect the air bag wire before anything. If you can't find accurate info on the procedure i would seriously advice taking it to the dealer (at least to get the airbag disconnected).
Old 01-24-2011, 07:24 AM
Quote:
I absolutely agree with you Encho, air bags shouldn't be messed with unless you know what you are doing.
I personally wouldn't mess with them either, but I think tim189 was already past that point. I think I read he was down to the aluminum housing.
Old 01-24-2011, 07:56 PM
I'm past the air bag and now have replaced the bad bearings. Now my new problem is re-installing everything. If I attempt to bolt up the housing with the tilt wheel spring in place my ignition actuator doesn't go all the way inside the housing. If I put the housing on without the spring the actuator goes in as it should. I found something on the net that says to put the spring in after you bolt up the housing using a screw driver or pry bar. I've tried that and there is no way, not enough room.
Are there any suggestions on how to get that spring in place?
Again thanks in advance for any help.
Excessive play in steering column eric8 1973 - 1979 F-100 & Larger F-Series Trucks 7 03-09-2017 10:55 AM
Steering Column lower bearing Jmwinter 1973 - 1979 F-100 & Larger F-Series Trucks 19 11-11-2016 04:15 PM
Steering column rebuild workingdog 1967 - 1972 F-100 & Larger F-Series Trucks 31 10-10-2016 02:21 PM
Looking for a Steering Column DuallyF350 1987 - 1996 F150 & Larger F-Series Trucks 2 05-12-2015 08:12 PM
Hanging pedal and steering colum... hwyhogg 1948 - 1956 F1, F100 & Larger F-Series Trucks 21 11-23-2010 02:07 PM
Tags
1993, 1996, 1997, 92, bearing, bearings, bronco, column, f150, ford, replace, replacing, series, steering, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
