Firing pattern - Ford Truck Enthusiasts Forums
Firing pattern
Old 01-23-2011, 10:59 AM
zlusmc zlusmc is offline
zlusmc is starting off with a positive reputation.
Firing pattern
I'm having trouble finding the firing pattern for my I6 300. I put a new distributor cap on, and didn't mark where the wires went on the old one as a reference. Can anyone help me out? Ive searched and I'm having trouble finding an answer.
Old 01-23-2011, 11:21 AM
4x4 Bart 4x4 Bart is offline
4x4 Bart is gaining momentum as a positive member of FTE.
Try 1-5-3-6-2-4
tinaheels's Avatar
tinaheels tinaheels is offline
tinaheels is starting off with a positive reputation.
fireing order is 1,5,3,6,2,4 in a clockwise rotation
Rear hubs on a 54, issue with re-drilling...need help Bozworth 1948 - 1956 F1, F100 & Larger F-Series Trucks 4 09-13-2011 06:53 AM
351w bolt pattern(bellhousing) stats2me Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 6 11-04-2005 08:26 AM
Pressure plate bolts for 11" clutch soacj Clutch, Transmission, Differential, Axle & Transfer Case 1 08-25-2005 10:12 AM
Help! Clutch for my 460 and ZF Mr Man Clutch, Transmission, Differential, Axle & Transfer Case 6 01-15-2005 09:03 AM
bolt pattern changing jniolon 1948 - 1956 F1, F100 & Larger F-Series Trucks 2 10-16-2002 08:09 PM
Tags
60, firing, ford, o6, pattern
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
