I am back to stay and need advice......
The Sylvania Ultra's will be much better than the stock replacement bulbs. You can get them at Autozone - easy to replace.
bulbs and such
Thanks, I just picked up a set. Good recommendation.
When I get all the fluids changed from diffs, training, coolent, oil, etc, etc. Do you have any recommendations on what fluids I should ask for? Also will get fuel filter, and anything else you could think of would be great.
I appreciate your replies!
going different
Thanks for the advice but I have leaned over the years (now a old wise man) that when you screw around too much you have problems. I think I will go with the Ford AIS where you have colder intake as compared to keeping it under the hood where there is warmer air.
As far as oil I believe I will go with the Rotella T 5W-40W during the colder months here in Eastern Washington. Oh, and a Wix oil filter.
Not be a smart ***, but if you've learned over the years, why use a WIX oil filter when the Motorcraft is just a good or better, and cheaper?
Colder air only matters for the Gassers. The 7.3L has a intercooler, which warms or cools the charge air to the temp of the engine coolant. So, regardless of how warm or cold the air is, the air temp going into the engine is at engine temp.
The 7.3 uses a air-to-air intercooler, the unit will get the intake air as close to ambient as possible.
A cold air intake means the air entering the intercooler is already cooler, thus by the time it travels through the intercooler, it is cooler yet.
#29
thanks
Yes, I will go with the Ford AIS. I am going to get all fluids changed (except for power steering and brake fluids). Also it was recommended by reputable independent shop here to get the front bearings packed at a cost of $250.00
I am looking into synthetic oil 5W-40W but on my old 99' 7.3 never had a problem with the delo. Opinion?
