Allow me to attempt to explain this...There is a "Terminal" that is fitted into the fuel bowl towards the bottom, The heater element plugs into this terminal from the inside. There is the wire that is protected by fuse #22 that plugs into the terminal from the outside completing the circuit.
Hope this helps.
Rog
ok yea that helps thank you. but is there a replacement external wire cause mine is cut and its a pita to keep crimping it back together and just want to replace it.
