Is my EGR bad?
Is my EGR bad?
hey guys,
so this is my first diesel and i completely absolutely and complete completely love it BUT i'm not in the "know" about all of it (these new engines are just to high tech for my simple little mind )
I've been reading on here that a lot of you had to have the EGR replaced because it was faulty or (i believe i read) that coolant/water leaked into it. i also saw in here that Ford apparently fixed the problem (job1/job2...??? not sure what that meant but i read while searching EGR threads)
I have a 2010 F350 and want to get rid of that d@$n DPF . not only is it horrible it's really just plain dumb...anyway. i have figured out how i'll go about doing this but it will end up voiding my warranty. so, before i do the exhaust mod i would like know what i need to look for concerning the EGR so that if it does go bad i may catch it before the warrenty is no good. i would assume that because my truck is newer that my EGR is "the better one". but we all know what happens when we assume. i've also read that white smoke out of the tail pipe is a sign of the bad EGR but it's also in a few threads about regen. how do you tell the difference???
also, since i'll be deleting the DPF i believe i've read doing a EGR delete along with the DPF. what is the benefits in doing this and how is it done?
thanks so much in advance for any help
The 2010's as far as I know have not had to many problems with the EGR. I think most of the early 08's had the problem. I would do some research on how to delete and/or turn off the EGR and how it may affect your warranty. Good luck and welcome to FTE there are a lot of good people on here that have good information and knowledge!
Ed
Ed
and by the way thanks sportsfreaked
if i run it hard? i live in South Dakota so my landscaping business is pretty much non existent throughout the winter (which is what i primarily use the truck for). there fore i work a seasonal job doing snow removal on the Air Force base and just use the truck as a daily commuter about 6 months out of the year besides the few times a may make a loaded landfill trip or help a buddy haul something. so am i actually harming the engine by not using it to it's full potential? also if the EGR is deleted and all the excess boost has no where to go, you are saying that it will harm the turbo? and if so why do people delete it?
