Bypass Oil Filter kit installation with pictures - Ford Truck Enthusiasts Forums
Old 01-23-2011, 02:53 AM
Von-Overkill's Avatar
Von-Overkill Von-Overkill is offline
Von-Overkill is starting off with a positive reputation.
So I decided to add the benefits of a dual bypass filtration system to my new F450.
The idea was to give the truck more advantages than dino oil could offer. I won't bore anyone by citing all the benefits, but one of them may be extended drain intervals. But with some of these engines "making oil", we will have to see with oil analysis where the extended drain sweet spot really lies.
On my last diesel truck (2006), the oil tested good to about 25,000 miles between changes (based on analysis). And I've been using variants of this system since 1986 with good success. I always liked the idea of reducing the dirt particle size that normally circulates in the engine even with a new filter and fresh oil. The standard filter could not be more efficient since it could restrict flow and cavitate. The answer was one full flow filter and one metered one, as in the system below (though other combinations are possible).
Not really trying to sell anyone on this, but for those considering, I thought it might be nice to contribute some installation pics.
Engine turns over pretty easily at -20 degrees without plugging in. Supposed to be more slippery, but I'm sure the reduced friction results in minimal mileage gains. Engine seems to run about 6 degrees cooler on the freeway.
I had to figure out where to put everything, and it took more than half a day in a heated garage bay. As big as these trucks are, there isn't spare space in the engine compartment for this kit.
Ended up with a vertical install to the outer frame rail on the passenger side, right around the transmission crossmember. The only thing the kit lacked was touch up paint and a sampling petcock (optional). Added split rubber hose over the oil lines in possible chafing areas, and zip tied the whole mess up high against the floorpan. Put several thousand miles on it since with no issues. Will be taking a sample soon, to establish a baseline.
I apologize for the less than optimal cell phone camera, and my crummy formatting of this post. I did have some issues getting this all to work.
Old 01-23-2011, 03:24 AM
Somehow most of my pictures got stripped from the post, and "insert image" doesn't seem to be working for me anymore. Will try and add some more pics a little later.
Old 01-23-2011, 06:16 AM
j klug j klug is offline
j klug is starting off with a positive reputation.
whats the amsoil part number the web site still dose not show an applacation for our 2011 fords thanks J Klug
Old 01-23-2011, 06:42 AM
xrated xrated is offline
xrated is starting off with a positive reputation.
Deleted response!
Old 01-23-2011, 10:15 AM
rdenis's Avatar
rdenis rdenis is offline
rdenis is gaining momentum as a positive member of FTE.
Nice kit and instal... pics are pretty good for a cell. Thanks.
Old 01-23-2011, 11:10 AM
Great Danes's Avatar
Great Danes Great Danes is offline
Great Danes is starting off with a positive reputation.
Overkill, please post all the part numbers that you ordered, as I have been wanting to do this as well , but as mentioned, the AMSOIL website does not list anything for 2011's.
I see you are running the EABP-110, which full flow filter are you running on there? Also, could you post a pic from the side of the truck so we can see how far down the filter protrudes from the bottom of the frame rail? Thanks.
Old 01-23-2011, 12:23 PM
BMK-23 bypass kit (universal)
BK-300 engine spin-on adapter (1" x 16 same as Cummins I think)
EaO-26 full flow filter
BE-110 bypass element
Sampling petcock (didn't get yet)
API CJ-4 Synthetic 5W-40 Diesel Oil
At least I think those were the numbers. The whole thing sits way above the bottom of the frame rail (+/- 4"). I did not want it to stick below the rail, and if it did, I would have turned the housing sideways, which would have given me the clearance, but possibly increased loading forces with the long bypass element, and crack the housing.
I had a dealer in Northern Ohio who is very knowledgeable, help me with the list of parts. I then rented a garage and some help to install while I was on vacation there. I had no choice in timing since the "change oil" message came up on the dash while I was traveling, and I planned on doing it eventually anyway. Changed the oil first, then added bypass system a week later.
Old 01-23-2011, 01:43 PM
Thanks for the part numbers.
Quote:
In the one picture it already looks like the long filter extends below the frame rail by more than an inch or two?
Old 01-23-2011, 04:03 PM
Yes, it's below the frame by several inches with that length element. But what I meant to say was that it is above the transmission crossmember's lowest point by about 4 inches, so the clearance is good. You can always opt for the shorter catridge filter, and replace it more often. It is the same setup, you just fine tune the height with the appropriate bypass element.
Old 01-24-2011, 06:34 AM
Thanks Overkill, that clears things up for me. I think I will order the same setup once the weather gets a little warmer in a few months. Are you running AMSOIL DEO 5W40 as well?
Old 05-01-2013, 09:58 PM
hoshwlson hoshwlson is offline
hoshwlson is starting off with a positive reputation.
Is there any reason that you went with that kit instead of the kit that is specifically made for Tha 6.7 powerstroke
Old 05-01-2013, 10:16 PM
There was no specific kit available for the 6.7L at that time.
Old 05-02-2013, 02:10 PM
Chad149's Avatar
Chad149 Chad149 is offline
Deplorable
Chad149 has a superb reputationChad149 has a superb reputationChad149 has a superb reputationChad149 has a superb reputationChad149 has a superb reputationChad149 has a superb reputationChad149 has a superb reputationChad149 has a superb reputationChad149 has a superb reputationChad149 has a superb reputationChad149 has a superb reputation
Any problems to report and what have your analysis reports saying?
Old 05-02-2013, 02:16 PM
No problems at all. Fuel dilution is the main limiter to extended drain intervals with a disel using a regeneration system. Next concern would be TBN. The other things are much easier to manage, assuming you are using synlubes designef for maximum performance.
Old 04-11-2014, 09:46 AM
Agg2001's Avatar
Agg2001 Agg2001 is offline
Agg2001 is starting off with a positive reputation.
random search... and then a chat with an amsoil dealer buddy.
found this link - one kit nowadays.
AMSOIL Ford 6.7L Engine Dual Remote By-Pass Filter Kit
79' F250 4x4 progress thread BIGT94z 1973 - 1979 F-100 & Larger F-Series Trucks 57 01-04-2014 06:07 AM
My L8000 project proline69 Large Truck 14 02-17-2013 10:40 AM
King Coilovers installed w/picture Von-Overkill 6.7L Power Stroke Diesel 5 10-12-2011 06:45 PM
My 69 F100 Ranger Project TXstroker01 1967 - 1972 F-100 & Larger F-Series Trucks 25 07-29-2010 11:56 AM
"New" Project preppypyro Manitoba / Saskatchewan Chapter 15 05-10-2010 12:24 AM
Tags
2006, 2011, 67, 97, benefit, bypass, f150, filter, ford, kit, kits, oil, picture, powerstroke, recommended
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
