4r100 check balls in valve body - Ford Truck Enthusiasts Forums
Old 01-22-2011, 08:49 PM
blockzilla blockzilla is offline
blockzilla is starting off with a positive reputation.
4r100 check ***** in valve body
99' f-350 7.3 diesel .......Ok yesterday I pulled up to the store -- left truck running in park.. came back out put it in drive .. nothing .. like its in neutral... but it did have low gear so drove it home slowly in low... fluid level good. Never had any problems before .. then all at once ??? pulled the pan today dropped the valve body .. found one of the 3 feed bolts a tad loose ( finger loose) .. tightened it back up ... now heres the problem . after dropping the accumulater plate i only had 7 ---5/16" Checkballs on the floor in the fluid puddle and all the info i can find on the web shows 8 .. but I cant find info on the 99' model .. anybody got the info on how many I should have ?? and location. I have found some pics showing 8 .. If i'm suppose to have 8 then I'm screwed.. if 7 which one do I leave out ? any one of you tranny guys have a spare 5/16" ball you could send me if I need an 8th one ? thanks ... gonna have to walk to work if I cant get this fixed quick...
Old 01-22-2011, 11:43 PM
shark13 shark13 is offline
shark13 is starting off with a positive reputation.
5/16" seems kinda large. In any case I have a few extra checkballs from a recent rebuild but they are 7/32". If you can use one I'd be happy to send it to you.
Old 01-23-2011, 08:06 AM
checkballs
they definately are 5/16" ... they measure .312 .. the holes that they cover are very large also . the smallest ***** this tranny uses is 1/4" . I'm afraid the 7/32 ball would fall thru the hole . but thanks for the offer...
Old 01-23-2011, 09:44 AM
jk080's Avatar
jk080 jk080 is offline
Gear Head
jk080 has a very good reputation on FTE.jk080 has a very good reputation on FTE.jk080 has a very good reputation on FTE.jk080 has a very good reputation on FTE.
Here ya go this should be what you need.
Name:  4r100 check ball 2.JPG
Name:  4r100 check ball.JPG
Old 01-23-2011, 01:13 PM
thanks alot man thats great - now it looks like I gotta find me a .312 ball check ..... no ford dealers for 40 miles in any direction..gonna have to see what I can do after work tommorrow to try and get to one....
Old 01-23-2011, 04:30 PM
Thanks everyone for the responses and photos.. I'll be reassembling today .. crossing my fingers
Old 01-25-2011, 10:26 AM
update . Tightened forward clutch feed screw - put valve body back in ..and went from no drive at all to drives like a new one...
Old 02-06-2015, 05:47 PM
widdowmaker widdowmaker is offline
widdowmaker is starting off with a positive reputation.
forward s rew
My pickup did the same thing... just So i don't screw up where is that screw at
Old 04-28-2016, 05:27 PM
jonothan.hall jonothan.hall is offline
jonothan.hall is starting off with a positive reputation.
Can any one give me a diagram on the placement of the check ***** on a 98 4r100
O-ring source for 5/16 & 3/8 fuel line connectors? richardfine 1987 - 1996 F150 & Larger F-Series Trucks 7 09-10-2016 02:25 PM
Tank switching solenoid and fuel line size abstractbart 1973 - 1979 F-100 & Larger F-Series Trucks 12 08-16-2016 04:17 PM
302 with 5/16 valve stems Lneidlinger 1967 - 1972 F-100 & Larger F-Series Trucks 3 10-01-2015 05:39 AM
looking for 2 5/16" stainless steel hitch ball with >10K rating Ultraboy Excursion - King of SUVs 26 04-24-2015 08:50 AM
E4OD Transgo shift kit install hav24wheel 1987 - 1996 F150 & Larger F-Series Trucks 2 11-16-2009 06:22 PM
Tags
4r100, air, ball, balls, blockzilla, bodie, body, check, exhaust, ford, location, temperature, test, transmission, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
