4.2 intake water leak at heater hose - Ford Truck Enthusiasts Forums
Old 01-22-2011, 03:37 PM
sleepinghound sleepinghound is offline
sleepinghound is starting off with a positive reputation.
Question 4.2 intake water leak at heater hose
I have a 1999 f-150 2wd w/4.2. On the front of the intake manifold there is a metal tube molded/pressed into intake. This tube has a hole in it and is leaking. Is there a fix for this or does entire manifold need to be replaced? I used JB weld on it and it worked for a while but then it softened and started to leak again. Any help would be appreciated. Thanks
Old 01-22-2011, 03:42 PM
99RatFinkFord99 99RatFinkFord99 is offline
99RatFinkFord99 is starting off with a positive reputation.
this happend alot in the 1997-1999 4.2l's after about 100k the manifold would leak into the top end...i think i heard that ford had a callback on that but im not sure, but the best thing to do in this case is to replace the manifold...
Old 01-22-2011, 09:24 PM
moto57's Avatar
moto57 moto57 is offline
moto57 is starting off with a positive reputation.
Old 07-16-2011, 04:49 PM
mrv8outboard's Avatar
mrv8outboard mrv8outboard is offline
mrv8outboard is starting off with a positive reputation.
I realize this is an old thread but I would like to update it as I just repaired a lower intake bypass pipe.
1st I first removed the old pipe and the piece left in the intake.
2nd Was to drill the hole with a 13/16" drill bit and chambered the leading edge with a 7/8" drill bit.(This was to make the lead in for the tap).
3rd Tap the hole with a 1/2" pipe tap. (I used 95% of the taps depth).
4th Assembled a 1 1/2"x1/2"NPT nipple into a 90* fitting and out of that with a 1/2"NPT x 3/4" barbed nipple.
5th Installed this assembly and the intake was fixed. (Now came the rest of the upper intake assembly).
Old 04-03-2012, 07:14 AM
renchr56 renchr56 is offline
renchr56 is starting off with a positive reputation.
update to this old thread
I found a replacement Ford OE part.. # F75Z-8555-AB. This is the exact part to the one that continually rusts out.
First I cut off the old tubeflush. then I took a small ( and I mean small ) hacksaw and cut throught the remaining piece that is still in the manifold. I then could get the piece out. I then coated the new piece with gasket shellac and made a homemade driver out of 1/2" pipe by cutting one side off. I used it to drive the new pipe home. Works great and no leaks.
2000 F-150 F-150 Mark 3.8 & 4.2L V6 1 03-23-2014 08:18 AM
Ford 4.2L lower intake manifold interchange years? lilflippy 3.8 & 4.2L V6 0 06-22-2012 05:12 PM
Coolant leak 1997 f-150 2pd519 1997 - 2003 F150 3 08-18-2011 07:52 PM
5.4 coolant leak/intake problem ? HELP !! beel61 Modular V8 (4.6L, 5.4L) 1 05-20-2009 07:10 PM
Coolant Tube on Intake Manifold Broken boz85gt 1997 - 2003 F150 9 10-31-2007 09:26 PM
Tags
2000, 42, 42l, f150, ford, heater, hose, intake, leak, leaking, line, manifold, pipe, tube, water
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
