anyone using E3 sparkplugs
My 2002 v10 is due for new sparkplugs. I was wondering if anyone here is using the new E3 sparkplugs. Are they all hype like the splitfire plugs were when they came out, or are the E3s worth buying. I bought a set of splitfires when the came out, and it was a waste of money. I was also thinking about buying some of those Accel silver sparkplugs, I saw those for sale on summitracings websight.
Last edited by shore; 01-19-2011 at 03:36 PM. Reason: Accel Silver plugs not motorcraft
The ignition system in these is strong enough to work perfectly well with just about any plug.
Motorcrafts are extremely reliable, inexpensive, readily available. Perfect.
ANY "snakeoil" plug will perform better if you use them to replace seriously worn out plugs. Heck, that's how the marketing slimebal....errr.... experts arrange for those neat numbers to use in the ads.
Replace a good motorcraft with snakeoil plug? I GUARANTEE you will NOT see any repeatable positive improvements.
Iridium or double platinum (on both electrodes) will last longer without maintenance, but I change ANY steel plugs in aluminum heads at 50K miles anyways to avoid thread seizures.
ptt
30
08-25-2017 10:11 PM
Pantera-nm
04-13-2005 02:24 PM
