fan/heater stays on after shutting truck off? - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 01-21-2011, 11:29 PM
'99-v10-F350's Avatar
'99-v10-F350 '99-v10-F350 is offline
'99-v10-F350 is starting off with a positive reputation.
Exclamation fan/heater stays on after shutting truck off?
So when i shut my truck off the heater will occasional keep blowing. it also has a string of LED type lights inside the dash by the speedometer, those also stay on sometimes. It's happened before and we thought we had it fixed. We had a whole new fuse box put in and some kind of module. Does anyone have any ideas of what could be the problem? im thinking maybe some kind of wiring? i appreciate any replies
Old 01-21-2011, 11:40 PM
99f350sd 99f350sd is offline
99f350sd has a good reputation on FTE.99f350sd has a good reputation on FTE.
This is becoming more common.. The blower motor relay is what controls the motor..
When it stays on do you have all the speeds? Pull the blower relay see if it stops.
Does it go off when you put the blower switch to off..?
Old 01-22-2011, 12:15 AM
yes all the speeds work just fine, and i've tried putting it to off but you can still hear it running. But i'm not real mechanically/electronically inclined when it comes to stuff like this, care to tell me where the relay is?
Old 01-22-2011, 07:04 AM
Under the hood in the fuse relay box. Do you have a standard dash heater control etc off is up..?
Old 01-22-2011, 10:51 AM
WestCoastTodd WestCoastTodd is offline
WestCoastTodd is starting off with a positive reputation.
Is there any sign of water in the cab, driver's side? If the windshield is leaking, it will run down the a-pillar, and drip right on the fuse block and GEM. The blower staying on is common - happened to me. You have to take off the two big connectors on the back of the fuse block and blow them out with compressed air.
Old 01-22-2011, 05:34 PM
Funny thing on the 99 the gem doesn't have anything to do with the blower stuff..Now the fuse box does if it shorts...At least on my 99 CD.
Old 01-23-2011, 12:43 AM
Well I found the fuse to it so I pulled that for tonight so it didn't die on me again (didn't pull it last night, went to go to work and what do you know batteries dead) but I'm gonna get a new relay tomorrow and I noticed a few blown fuses so I ned to replace them while I'm at it.
Old 01-23-2011, 01:13 AM
Boss_hoss's Avatar
Boss_hoss Boss_hoss is offline
Boss_hoss is starting off with a positive reputation.
I have the same problem, I have a leak in the windshield like WestCoastTodd mentioned. When it started there was no indication of the leak because it would run along the headliner then down the pillar and shorted something out. you may want to check that out. Also in my case I just turn the heater control to off when I trurn the truck off and the blower will turn off. Its easier than pulling the fuse whenever you want the blower off.
Old 11-13-2013, 10:06 PM
rehpig rehpig is offline
rehpig is starting off with a positive reputation.
I have this same problem. Did the blowing off of the fuse connectors fix the problem? I also have a problem with the daytime headlights coming on arbitrarily
Old 11-14-2013, 12:02 AM
madsonp's Avatar
madsonp madsonp is offline
madsonp has a good reputation on FTE.madsonp has a good reputation on FTE.madsonp has a good reputation on FTE.
Quote:
Ditto on the windshield leak, that's probably why you had to have the fuse panel and GEM replaced in the first place, take it in and have your windshield resealed, then dry out your fuse panel and GEM.
heater shut off valve bigbubba87 1999 - 2003 7.3L Power Stroke Diesel 20 10-10-2012 07:55 PM
Heater problems Vinford 1999 - 2003 7.3L Power Stroke Diesel 9 11-19-2010 10:47 AM
Need Help! visor keeps leaking!! maverick 21 1999 to 2016 Super Duty 1 02-06-2008 06:52 PM
power draw with key off.PLEAS HELP palmer1998 1997 - 2003 F150 7 12-16-2006 09:55 AM
windshield wipers stay on rsuszek2 1987 - 1996 F150 & Larger F-Series Trucks 1 07-15-2006 12:24 AM
Tags
2001, 2004, 99, dash, f150, f250, f350, fan, ford, heater, lights, on, stay, stays, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
