how to ID X-code springs? - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 01-21-2011, 08:18 PM
akorcovelos's Avatar
akorcovelos akorcovelos is offline
akorcovelos is starting off with a positive reputation.
I just got my build sheet from Ford, and it does not mention any Plow package, or heavy duty front springs. The only reason I thought it had them was the PO told me it had X-codes up front, and he used it as a plow truck.
Is there an easy way to visibly ID X springs?
Old 01-21-2011, 08:42 PM
2002 F350V10 2002 F350V10 is offline
2002 F350V10 is gaining momentum as a positive member of FTE.
Found this info on another forum when I was searching for some other spring codes. Hopefully this will help others.
a 2004 F SuperDuty:
Rear Springs F-Series
B 3C34-5560-L
C 3C34-5A975-D
D 3C34-5A975-G
E 3C34-5A975-K
J 3C34-5A975-J
M 3C34-5A975-E
N 3C34-5A975-F
P 3C34-5A975-C
S 3C34-5A975-C
2003 manual
Front Springs F-Series
B F81A-5310-EA
C F81A-5310-EA
D F81A-5310-EA
E F81A-5310-EA
F F81A-5310-FA
G F81A-5310-GA
H F81A-5310-HA
I F81A-5310-RA
J F81A-5310-JA
K F81A-5310-KA
R 2C34-5310-AAB, 3,600 lb.
S 2C34-5310-AAB, 4,000 lb.
T 2C34-5310-ABB, 4,400 lb.
U 2C34-5310-ACB, 4,800 lb.
V 2C34-5310-ADB, 5,200 lb.
W 2C34-5310-AEA, 5,600 lb.
X 2C34-5310-AFA, 6,000 lb.
Y 2C34-5310-VA
Z 2C34-5310-WA
B F81A-5310-EA
C F81A-5310-EA
D F81A-5310-EA
E F81A-5310-EA
F F81A-5310-FA
G F81A-5310-GA
H F81A-5310-HA
I F81A-5310-RA
J F81A-5310-JA
K F81A-5310-KA
Y 2C34-5310-VA
Z 2C34-5310-WA
Front Springs Excursion
B YC35-5310-ABC
C YC35-5310-ACC
D YC35-5310-ADA
G YC35-5310-GA
H YC35-5310-HA
S YC35-5310-SA
B 1C34-5560-CB also 3C3Z-5560-CB
C 1C35-5560-DB
D YC35-5560-EA
M YC35-5A975-AA
N YC35-5A975-BA
S- 3C3Z-5560-CA one you should get for EX spring swaps.
Rear Springs Excursion
A YC35-5560-A
Rear SD 30mm bar.. F81Z-5A772-AA
Old 01-21-2011, 08:46 PM
not sure how to read this? Which front spring list would apply to a '99?
Old 01-21-2011, 08:49 PM
1998-current
Example: Y F 1 H - 1 8 C 6 1 2 - A A 2000 Taurus Electronic Climate Control Module.
First Digit - Year
W - 1999
Y - 2000
1 to 9 - 2001-2009
A - 2010 etc.
R - 2024
Second & Third Digit - Model
S1 - Aspire
S2 - Contour
S4 - Escort
S6 - Fiesta
S7 - Mondeo
S8 - Probe
S9 - Mystique
F1 - Taurus
F2 - Windstar
F3 - Continental
F4 - Sable
F5 - Villager
F6 - T-Bird
L1 - Bronco
L2 - Explorer
L3 - F150 - F250
L4 - Maverick
L5 - Ranger
L6 - Aerostar
L7 - Navigator
R1 - Aston Martin
R2 - Falcon
R3 - Mustang
R4 - Scorpio
R5 - Fairlane
R6 - LTD
R8 - S Type Jaguar
R9 - Mark VIII
W1 - Town Car
W2 - Cougar
W3 - Grand Marquis
W4 - Lincoln LS
W6 - RWD T-Bird
W7 - Crown Vic
C1 - Transit
C2 - Econoline
C3 - F250 +
C4 - Heavy Truck
Forth Digit - Design Responsibility (Mostly the same as before)
example: C - Chassis Operations
H - Climate Control Operations
T - Electronics Systems Engineering
Center Numbers - Specific component (Same)
Minor correction. Parts are numbered with even numbers except when in pairs - then even numbered parts are passenger side components and odd numbered parts are drivers side components.
Final two digits - Design Level.
AA first design, then AB, AC, AD, etc. BA or CA would be a part that was the same function as the AA but slightly different.
Old 01-21-2011, 09:00 PM
how does ^^^ that apply to this: X — 2C34-5310-AFA, 6,000 lb.
Where on the springs would the part number be stamped?
Old 01-21-2011, 09:07 PM
Sometimes information is spotty, but here is what I found out. I needed a replacement set of springs for a 99 4x4 superduty. I eventually found a pair of new take offs which then sat unused for many years being advertised locally on craigslist, and when I called , they were only 3 miles away. Since I never saw the truck they were from, I bought them based on the correct dimensions being checked with a tape measure , along with the seller stating they were for a leaf spring superduty. Stamped on the springs on the bottom towards the rear was 2C34-5310-ADB , so after many exhaustive net searches. I found reference they are "V" code springs from a superduty truck not older than 02.
They are going on a standard cab 7.3 99 F250 4x4 pickup when ever the weather gets warmer up this way, and considering the originals are worn out 200,000 mile originals , I hope it works well.
Start by getting the part number off your springs first, then see if what the chart listing I gave matches anything, and if not, search by part number you have found.
2C3= 2= 2002 C3= F250+ 4=design responsibility 5310= leaf springs ADB=weight rating of 5200 lbs.
Actually the year indicates the first year this part was used in production.
Old 01-21-2011, 09:50 PM
good info, I'll check the springs tomorrow in the light, thanks!
Old 01-21-2011, 09:59 PM
Mike F250 SD Mike F250 SD is offline
Mike F250 SD is starting off with a positive reputation.
It should b on the tag in the door jam. If he put them in after then I'm no use to u lol
Old 01-21-2011, 10:25 PM
If it does have them, then he must have added them since they are not mentioned on the factory build sheet. I would think the door tag would match the build sheet, no?
Old 01-25-2011, 06:54 PM
so this is the numbers off my springs. I noticed there are 3 leaves though, is that normal?
I see a lot of F81A numbers, but nothing ending with AED?
Old 01-25-2011, 10:20 PM
Is there any way to tell which F81A spring I have, and are they supposed to have 3 leaves or two?
Old 01-25-2011, 11:16 PM
99f350sd 99f350sd is offline
99f350sd has a good reputation on FTE.99f350sd has a good reputation on FTE.
X springs are two leaves..Don't know what 3 leaves means. Someone added a leaf maybe.
Old 01-25-2011, 11:33 PM
Old 01-26-2011, 01:26 PM
I dunno, I guess I don't understand how to decode these numbers...
My springs are stamped F81AAED and RPN 2438, so do I go by the F81, or the RPN?
If F81, which one is it sonce there are several F81 springs listed above, but none listed as AAED.
If R springs, what does the other two letters mean in RPN, and what does 2438 designate?
also, my springs have 3 leaves, so I'm guessing the PO added a leaf?
Old 01-26-2011, 04:03 PM
http://www.ford-trucks.com/forums/93...ity-chart.html
Read the bottom anout the 3rd leaf...
How to tell springs apart IDI-Charlie 1999 - 2003 7.3L Power Stroke Diesel 7 10-01-2016 07:55 AM
Bottom front leaf on a V or X code BeachEx Excursion - King of SUVs 5 01-23-2014 03:24 PM
99+ super duty V-code and B-code or F-code springs bigwhitetruck01 WTB - Parts & other 1 04-18-2013 11:32 AM
Excursion and a snow plow ? wannaBelkhuntin Excursion - King of SUVs 21 11-17-2012 09:24 PM
X-code C-code spring part numbers bobalonius Excursion - King of SUVs 0 03-22-2012 06:04 AM
Tags
2010, 3c34, 5310, 99, cb, code, diesel, engine, f150, f250, ford, spring, springs, vvaa, yc35
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
