Rod Knock???
Rod Knock???
My buddy has a beautiful 2005 F-350 Super Crew SRW with the 6.0 Powerstroke and just under 100,000 miles on it. Coming home from the Carolinas this past weekend he started blowing smoke & had a noise......this is what it looks like.
Rod knock? - YouTube
So what's the diagnosis Doc?
He dropped it at the dealer and they replaced the EGR cooler & the pump. But the noise is the same and the smoke is still there - same as when he was driving. Under load the noise goes away, when he takes his foot off the pedal & coasts or idles it comes back.
He put around 200 miles on it like this - I don't see any rod flopping around for that long without seizing the motor. What else could it be?
on
Excuse my ignorance...The dealer Fixed the EGR cooler...what pump?
Anyways, they let it go back out with it still smoking and knocking?
Could it be possible, the injector tip broke off? and its slapping around in there?
Here is a video of my injector knock......
Notice the smoke, my egr cooler was also bad, and 2 injectors went at the same time..Doesnt knock as long as yours, but you can hear the sound
This is what my 2 bad injectors looked like obviously extremely black and you cant even see the colors of the o rings anymore
Cracked nozzle......
When you rev it up to about 2-2.5k does the knock sound better? You have a cracked/broken nozzle. I will bet on it. And if I am correct and he is driving it, he WILL melt a piston if he hasnt already. Unscrew the oil fill cap at idle. Got pressure coming out??? Puff, puff, pufff,???? Thats bad.
