1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
going to buy a 00 expedition with a 4.6L YES it need work but how much
Old 01-21-2011, 08:12 PM
MY F 250 2WD's Avatar
MY F 250 2WD
MY F 250 2WD is offline
Originally Posted by MikeD1980
even if trailing arms are rusted, hit the junkyards.
very true at first i was thinking every one did not wrench but there is some ppl that do
Old 01-21-2011, 08:14 PM
MY F 250 2WD
my Lincoln LS I used to have had the COP's too, when one went bad it misfired alot too while driving. I would hook it up to a scanner and see if it tells you which cylinder has a misfire and go from there. Replace all plugs, air filter, pcv's, and maybe clean MAF sensor. While you are at it I would clean the IAC just cause. 140k isn't alot of miles, I have a real hard time believing it is more then a COP or sensor or something like that.
cops = coil on plugs ??
Old 01-21-2011, 08:26 PM
pdqford's Avatar
pdqford
pdqford is offline
Originally Posted by MY F 250 2WD
i am thinking of spending around
used tires 113.00 265/70/16 set of four 113.00 yok geolanders
two u joints 10.00 ech total 20.00 + tax
coils x8 120.00 total
then rockers $50.00 20 g sheetmetal seem sealer
breaks new lines pads rotors $150.00 +
total will be around $453.00 just parts
then got to figure out what i need to do to remove spark plugs
Wow! You got some good prices.
I put 4 GOOD rotors (Centrix), Ceramic pads all way around, 4 new calipers, and new e-brake shoes on my Navi. My price just for the parts was near $600.
Check the condiction of the tranny cooler lines - they tend to rot out.
Check the condiction of both front wheel bearings/hubs - big bucks for quality parts.
Jack it up and check each upper and lower ball joint as well as all tie rod ends. Of course, with 140k maybe they have already been replaced once.
Old 01-21-2011, 08:27 PM
MikeD1980's Avatar
MikeD1980
MikeD1980 is offline
yeah. Coil on plugs. Hate them! Stupid lincoln i had, they were $55ea. Was replacing like one a month, got fed up an ordered a new set of 8 on ebay, that lasted 6 months and started again, one at a time. So 2 weeks ago I traded the lincoln for a 97 Eddie Bauer Expedition that's lifted on 35's. Has it's share of issues too. Spent last weekend at the junkyard gettng parts and working on it. I like wrenching, keeps me busy. Fire up the torpedo heater in the garage and crank the radio and clear my head.
Old 01-21-2011, 08:32 PM
MY F 250 2WD
yup totally the way i like it
Old 01-21-2011, 09:16 PM
MY F 250 2WD
ok i can get a trailing arm upper and lower for $30.00 ech not to worried about that ether but thanks for the heads up
Old 01-21-2011, 09:24 PM
97ExpGuy's Avatar
97ExpGuy
97ExpGuy is offline
Don't forget your time in this project as well and depreciating values. The vehicle is never going go up in price. Like all (well, most) cars, we technically are throwing our money away. Add in $500 you stated plus another $350 to $400 in fluids (transmission, transfer case, front and rear diffs, coolant, and oil) and now you have doubled your cost to a $2200 Expy that you still need to spend hours upon hours on repairing. Don't forget that you need to do bodywork which is fitting panels, sanding, priming and painting. How much do those materials cost?
On top of this, how long do you plan on keeping this vehicle? it's already eleven years old.
Again, I'm not here to be the pessimistic one; I'm hoping that you won't get set on one Expy just because of the low price. When I bought my 97, it had 107k on it, one owner, always garaged and very, very clean. I paid $3500 for it and it has been worth every penny. Besides fluids and tune up, I haven't had to do anything else.
Old 01-21-2011, 09:46 PM
MY F 250 2WD
i have been a mechanic for over 15 yrs first oil change i ever did was on a 1987 doge did the oil change buy my self did my first motor rebuild when i was 15yrs old i am 30 now be leave me when i say this i know what i am getting my self in to truthfully fluids max 150 and that is pushing it
Old 01-21-2011, 10:55 PM
MY F 250 2WD
ok i was thinking about it and i know this is the expedition section but lets take a look at the work i have done
1993 F250 2wd $500
FROM THIS
TO THIS
MY BUDDYS 52 DELIVERY SEDAN AT THIS MOMENT RAT ROD WITH CHOP SUICIDE DOORS NOTICE DOOR
Shelby Daytona (a factory 5 build)
i am not bragging
and last pic my sheet metal work rocker on a 99 Ford taurus see a year from now ill show you a picture of the expedition and you will not relize it is the same thing thank you to the people that has helped me
Old 01-22-2011, 11:44 AM
Moto Mel's Avatar
Moto Mel
Moto Mel is offline
I LOVE the Rat Rod with it's doors,Mercury front end, frenched headlights, Corvette grill and Pontiac bumper and the sedan delibery body. Truely a work of art in progress. I would like to see more of it when it is finished, if it ever is.
Old 01-22-2011, 08:56 PM
MY F 250 2WD
Expedition was junk rear of expedition rusted out floor / frame
Old 01-22-2011, 10:56 PM
fordno1's Avatar
fordno1
fordno1 is offline
Save your money and find another. Now you have a really good idea of what to look for. Good luck!
  #28
Old 01-22-2011, 11:13 PM
MY F 250 2WD
yes i do i found this truck no rust 97 f150 2wd 122.000 miles 4.6l
By hydetherat at 2011-01-22
  #29
Old 01-23-2011, 06:58 AM
tseekins's Avatar
tseekins
tseekins is offline
Received 1,217 Likes on 800 Posts
Where in Maine are you?
  #30
Old 01-23-2011, 09:12 AM
MY F 250 2WD
[quote=tseekins;9865257]Where in Maine are you?[/quo
i live in Bangor
Quick Reply: going to buy a 00 expedition with a 4.6L YES it need work but how much
