detroit 6v92 77' f750
Brothers, iv got a 1977 F750 (vin#F75FVO85xxx) trans code 7. my question is will a 6v92ta bolt into this truck with that trans? was that truck avalable with that engine from ford ? from what i can gather the motor has a SAE 0 fly wheel/clutch & bell patern. has a 389 gas in it now. any help ? thanks
ford never used that engine to my knowledge in there f- series trucks and that is one big engine for that truck and the transmission that is in there now would never hold up to the power of the 6v92 !
if you did use that engine it would be a slow mover as the gears in the rear will be geared for a higher reving gas burner ( geared to low )
To my knowledge, Ford did not offer a diesel in the F-500/600/700/750 until 1980-81, and more than likely your gas engine is a 391 of the FT family of engines, don't recall ever seeing a Ford 389 though.
A 6v92 Detroit is way too big to even think of fitting in that truck. A 6v53 would be more of your speed, and probably would have a higher chance of bolting up to your transmission. You tube has several videos of F-250 and F-350's from the 70's that have had 6v53's put in successfully. F-series trucks that utilized pickup cabs never had diesels so far as I know, the industrial cab FT-series and L-series did however, but they had Cat 3208's, some variation of a Cummins, or a 6v53 Detroit.
Almost forgot about the Dorset engines were also available
F = 391 4V Xtra Duty FT engine (a 389 is a detuned for emissions 391, otherwise it's the same engine).
V = Kentucky Truck Assembly Plant.
O85XXX = 1977.
7 = Spicer model CM-5052-A 5 Speed Direct.
Diesel engines were first offered for 1962 F600's (Dagenham or Dorset, 1968 for I-6 Cats), but no F500 of any year ever came with one.
From 1968-79 Ford offered 3208 Cat V8's in F-600's and F-700's. They were labeled F-6000 and F-7000. They weren't common back then, and they are a rare site today.
The 3208 was actually designed for Ford to replace the 534 gas engine in 1968. They were painted blue, and labeled V-175 (for the HP rating) until 1975. From 1976-79 they were still blue, but the model changed to V-636 (for the displacement). The HP and torque specs gradually increased a few times, but it was still the original 3208.
In the early 80's, they were painted yellow, but still had the FORD V-636 labels on the dome covers. Eventually, they just got CAT 3208 logos. I would imagine that the contract with Ford was up at that point, because 3208's were showing up in all makes of trucks and equipment by then.
Chuck
Chuck
The question was about Diesel availability in F-series specifically, and that's what I answered about. Only the F-600 & 700 models could be had with a diesel, and only the 3208 was available. The engines you mention were available in other, non F-series models, as you stated.
Chuck
Wont bolt in but it sure would be cool.
Ive got a 18000lb '66 f850 with a 6v71 NA that goes pretty good. That 92 would be an absolute monster!
I put a different rear axle in mine with 3.55 gears for the highway. Also has a 10 speed and 4 speed brownie with OD.
Works great. Wouldn't mind the TA though..
Chuck
Ray,
Chuck
Chuck
*F-6000 (January 1968 to 1974)
Cat 1145 (V-175, 175 hp @ 3,200 rpm):
*F-6000, 7000 (January 1968 to 1974)
Cat 1150 (V-200, 200 hp @ 3,000 rpm):
*F-7000 (January 1968 to 1974)
Cat 1160 (V-225, 225 hp @ 2,800 rpm):
*F/T-8000 (January 1968 to 1969)
Cat 3208 (also called "Ford V-636" from 1975-80) (175 or 210 hp @ 2,800 rpm NA; 225 or 250 hp @ 2,600 rpm turbocharged):
*F-7000 (1975 to 1979, 1983 to 1990)
*F/FT-8000 (1983 to 1990)
jl429
22
03-04-2019 10:27 AM
Martin Torres
05-20-2017 09:41 PM
92BroncoMan
1978 - 1996 Big Bronco
05-01-2016 09:51 PM
