rear locker and front ls
OK i want to lock up the rear axle so when I'm in the sand or mud i have both wheels going the sand it for pismo beach and the mud is at my gf place for the rear i was think about a lock right locker Lock-Right locker for Ford 10.25" - PT 1840 cause it use the factory carrier and for the front EATON ELOCKER E LOCKER DANA 60 35 SPLINE 410D 19760-010 - eBay (item 370468402814 end time Feb-18-11 14:24:24 PST)
so i can turn it on and off when i need the traction but can turn it off when i need to turn oh and this truck is my dd
Id go with ARBs over something electric.
And unless youre buying something used Id stay away from Ebay. Plenty of good vendors that will sell you what you need at similar prices and offer service after the sale. The ebay douches probably have no idea what they are selling or how to install them.
Rich at Complete Off Road | Your Source for Off Road Parts - Axles - Driveline Parts and More gets my vote/business.
ARB AIR LOCKER-DANA 60-30 SPLINE 4.10 DOWN (RD22) whats the main diff with e locker and arb i know one use wires and one uses use air how hard are they to install
the e-locker comes with its own specific diff cover which has a solenoid mounted on it. with an arb you have to drill/tap your housing or cover for an air line fitting/hole. for a daily driver/beach truck i'd go cheap and just get a set of tracklock limited slips for both axles. they don't really bind the steering, especially on loose surfaces like sand.
if i had to build my own axles i would say powerlock all the way. hopefully i get these built ones i'm after.
joe's is a dd i think, so welded rear is out. but a cheapo trac-lock will work for the rear to save on cost.
i don't get the whole "selectable rear" argument. if you are going to spend that kind of cash, put it in the front, rear full lockers are not that harsh, unless you are a huge gapping vajeena of a man.
p.s. i had one when i first learned to drive in winter weather and it wasn't too hard to get used to and understand, and i was wasted half the time, so grow a pair and learn to understand yer vehicle a little if you have one.
V10E350
03-12-2015 06:22 PM
MK2Pierce
12-10-2014 06:38 PM
