what engine for boggin
#76
Yeah, that sounds good! I keep calling Nick trying to get my radiator back from him so I can take it and get it fixed but he won't call me back!!! Probably too busy with that blonde.... Last I talked to him he was having some troubles with his block heater, but haven't heard back since then. Also, for everyone's information I'm perfectly capable of rewiring the bish myself, but if the fat man offers for a case of beer or two, why not? :flipoff2:
#77
I wasn't implying I'd do it all myself. I was implying that since I do low voltage electrical work that I have all the tools to do it correctly and will help you fix your junk. Beer, meh, I'd rather do Captain!
Nick got his heater and glow plugs replaced, but now needs to replace the oil cooler as it's spewing oil all over the place. But hey, what do you expect from a 12 year old truck with over 300k miles on it.
#78
#79
#80
We need to get your wiring disaster fixed so you can reliably drive and mud your ho! I have the ranger at my house with the motor out again to prep it for the coming season. Once it's a little warmer you need to come down with some booze and wire and we'll re-wire the entire thing in an afternoon!
basically, i got my gauges put back in and the only factory one that works is the speedo, but none of the interior lights work, and being as all the fuses are good, i'm screwed because chasing electrical demons is not something i'm any damn good at. all i want is a few simple guages with lights, an ignition, heat for winter wheeling, and headlights/tail lights/blinkers/wipers. i figure a new simple race harness with blade fuses would be the best option for me to go, opinions????
#81
If the guages are no good, get some of the cheapy mechanical Autometer guages and wire from there. Parallel all the guage lights together on the running light circuit and then for the sending unit, the mechanical would be better so you don't have to worry about the electonic senders crapping out on you down the road. As for the harness, look at Painless since you already know wiring isn't your thing.
86pullerf350
05-21-2015 11:00 PM
dylan8427
18
04-04-2014 04:44 PM
toddpyles33
01-28-2012 03:58 PM
