I have slow/gummy ignition switch . . . sometimes sticks when starting . . . help! - Ford Truck Enthusiasts Forums
Old 01-20-2011, 12:19 PM
JoeVR5's Avatar
JoeVR5 JoeVR5 is offline
JoeVR5 is starting off with a positive reputation.
I have a 1990 F250, and my ignition switch feels gummy and slow.
I went to start my truck yesterday, and when I turned the key, I had to pull the switch back once it fired up, but the starter was still engaged for about 1-2 seconds.
I have owned the truck for a few years, and the ignition has always been a bit gummy, but it is especially bad in cold weather.
Is there any way that I can lubricate or loosen up my ignition switch so that it doesn't do this?
Any help would be greatly appreciated!
Old 01-20-2011, 01:17 PM
JoeVR5's Avatar
I just tried it again and this time, I quickly turned the ignition off and pulled the key out, and the starter was still engaging for about a full second.
Would WD-40 in the ignition cylinder fix this? Or electronics cleaner? I'm not too sure where to look . . .
If anyone can offer me any advice, I would be eternally grateful!
Thank you!
Old 01-20-2011, 01:19 PM
bren_tx bren_tx is offline
bren_tx is starting off with a positive reputation.
I think we all have had the same problem at one time or another. I have found that its not the switch itself but the moving parts inside the steering column. You would need to partially disassemble the column and lubricate the parts in there
Old 01-20-2011, 02:55 PM
JoeVR5's Avatar
I'm looking at my shop manual, and it is telling me not to spray any lubricant directly into the key hole . . . is this a really bad thing to do?
It's SO cold out here, I'm afraid of cracking the plastic housing around the steering column?
Is there a quick fix to get me by until the warmer weather? I generally hate quick fixes, but with these temperatures, it's tough to do extensive repairs on a vehicle without a heated garage.
Old 01-20-2011, 02:59 PM
88n94 88n94 is offline
88n94 is gaining momentum as a positive member of FTE.
It sounds like you have another problem, besides a sticky switch. It sounds like your solenoid is sticking. I see by your signature this is a diesel. This sticking solenoid may get worse and not stop cranking the engine. I would become familiar with the location of the solenoid and how it works in case it does stick, so you know what to tap on to stop the engine from cranking.
Old 01-20-2011, 04:17 PM
I didn't think so. At least with a gas engine setup. If the manual is telling you not to do so, there must be a reason. I'm not sure how the diesel switch is setup, but I would assume it's like the gas, in that where the key goes is just a tumbler and there is a rod connecting that tumbler with the switch about 4 inches away.
At any rate, I don't think lubricating anything in the steering column will solve the problem of the starter running a second or so after the switch is shut off. It could be the switch itself or the solenoid as I mentioned before, in my estimation anyway. I hope you get it solved before it gets worse.
Old 01-20-2011, 04:21 PM
onlya4.9's Avatar
onlya4.9 onlya4.9 is offline
onlya4.9 is starting off with a positive reputation.
i had the same thing happen to me, and my ignition cylinder was a little wore out, so i just spent the $20 and put a new one in it. i got mine at autozone and it came with 2 keys, and i just put a little wheel bearing grease on it before i put it in. it works perfectly now.
Old 01-20-2011, 04:57 PM
Rico47635's Avatar
Rico47635 Rico47635 is offline
Rico47635 is starting off with a positive reputation.
This is purely from an American ingenuitized do what ya gotta do until you can do better opinion, but what you could do is wire up a push button to engage the starter. Then you could use the key to put the ignition in the "on" position and the push button to engage the starter. I don't know if the setup is different on a diesel than the gas engines, but doing what I am talking about with a gas engine amounts to hooking up two wires to the starter solenoid on the inner fender and to the push button switch. Twenty minutes tops.
Old 01-20-2011, 10:52 PM
JoeVR5's Avatar
Thank you guys for the ideas!
I did have the starter motor and solonoid rebuilt at a shop last summer, so I don't think that could be the problem, but I'll definitely check it out.
I've driven quite a few Ford pickups, and the ignition lock cylinder on this diesel F250 just feels slow and gummed up. I don't think it's in the solenoid . . .
I love the idea of a push-button start if all else fails! However, I might go with a new lock cylinder before that . . . .
Old 01-20-2011, 10:56 PM
Onus's Avatar
Onus Onus is offline
Onus is gaining momentum as a positive member of FTE.
I thought this was a common ford issue you just learn to live with. Every time i crank the 91' up it seems to hold start a bit longer than it should and it grinds for a second. I start it like every other vehicle i have driven and those don't grind at all.
Old 01-20-2011, 11:04 PM
There is a little piece of pot metal in the column, some call it the tumbler, basically turns the turning of the key into forward movement of the ignition rod. The tumbler is the piece that needs to be lubricated, otherwise it will eventually break on you. Mine has broken twice...last time i replaced it, i lubed it up really good and now i dont have those cold morning sticks and hard-to-turn ignitions.
Old 01-20-2011, 11:11 PM
danger-ranger93's Avatar
danger-ranger93 danger-ranger93 is offline
danger-ranger93 is starting off with a positive reputation.
My 96 does this, does it even worse in the cold. But like the satin goes. Don't fix it if it aint broke and it still starts so when I start ****in money i'll fix it right. Lol
Old 01-21-2011, 12:52 AM
onlya4.9's Avatar
mine was all wore out and sticky and the key wouldnt come out of the ignition, so i replaced it. lol. i have to do the same to my chevy. lol
Old 01-21-2011, 12:43 PM
thechief66's Avatar
thechief66 thechief66 is offline
thechief66 is gaining momentum as a positive member of FTE.thechief66 is gaining momentum as a positive member of FTE.
Quote:
This is correct...except it's called an actuator. Very common problem on 91-older trucks. You can get a new one from Ford for only about $18 but they're a PITA to replace.
Old 01-21-2011, 01:53 PM
hammerhead90's Avatar
hammerhead90 hammerhead90 is offline
hammerhead90 is gaining momentum as a positive member of FTE.hammerhead90 is gaining momentum as a positive member of FTE.
I have this exact same problem. So this thread is of interest to me.
Funny story actually. I used to be able to start it without any keys. So I got used to leaving them at home for running errands. So I went to the dump one day, and while I was there, suddenly it decides it needs a key, and I had no cell phone. What an awkward conversation that would've been with the guys that worked there.Luckily I got it to start one last time without the key. Now I've needed one ever since.
Sticky ignition switch Lord Vokk 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 5 11-16-2016 11:51 AM
Gummy 3rd Brake Light Sockets FordTruckChuck 1997 - 2003 F150 0 03-31-2015 02:57 AM
Ignition switch/tumbler rf15eagle 1987 - 1996 F150 & Larger F-Series Trucks 6 01-12-2015 05:38 PM
Sticky ignition - an observation Dorsai 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 2 02-29-2012 07:34 PM
Intake manifold runner control hancockr Ranger & B-Series 2 02-08-2011 04:44 PM
Tags
88, 90, actuator, adjust, cylinder, f150, f250, ford, ignition, rod, slow, starting, sticking, sticks, switch, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
