I have slow/gummy ignition switch . . . sometimes sticks when starting . . . help!
I have a 1990 F250, and my ignition switch feels gummy and slow.
I went to start my truck yesterday, and when I turned the key, I had to pull the switch back once it fired up, but the starter was still engaged for about 1-2 seconds.
I have owned the truck for a few years, and the ignition has always been a bit gummy, but it is especially bad in cold weather.
Is there any way that I can lubricate or loosen up my ignition switch so that it doesn't do this?
Any help would be greatly appreciated!
I just tried it again and this time, I quickly turned the ignition off and pulled the key out, and the starter was still engaging for about a full second.
Would WD-40 in the ignition cylinder fix this? Or electronics cleaner? I'm not too sure where to look . . .
If anyone can offer me any advice, I would be eternally grateful!
Thank you!
Thank you!
I'm looking at my shop manual, and it is telling me not to spray any lubricant directly into the key hole . . . is this a really bad thing to do?
It's SO cold out here, I'm afraid of cracking the plastic housing around the steering column?
Is there a quick fix to get me by until the warmer weather? I generally hate quick fixes, but with these temperatures, it's tough to do extensive repairs on a vehicle without a heated garage.
It sounds like you have another problem, besides a sticky switch. It sounds like your solenoid is sticking. I see by your signature this is a diesel. This sticking solenoid may get worse and not stop cranking the engine. I would become familiar with the location of the solenoid and how it works in case it does stick, so you know what to tap on to stop the engine from cranking.
At any rate, I don't think lubricating anything in the steering column will solve the problem of the starter running a second or so after the switch is shut off. It could be the switch itself or the solenoid as I mentioned before, in my estimation anyway. I hope you get it solved before it gets worse.
This is purely from an American ingenuitized do what ya gotta do until you can do better opinion, but what you could do is wire up a push button to engage the starter. Then you could use the key to put the ignition in the "on" position and the push button to engage the starter. I don't know if the setup is different on a diesel than the gas engines, but doing what I am talking about with a gas engine amounts to hooking up two wires to the starter solenoid on the inner fender and to the push button switch. Twenty minutes tops.
Thank you guys for the ideas!
I did have the starter motor and solonoid rebuilt at a shop last summer, so I don't think that could be the problem, but I'll definitely check it out.
I've driven quite a few Ford pickups, and the ignition lock cylinder on this diesel F250 just feels slow and gummed up. I don't think it's in the solenoid . . .
I love the idea of a push-button start if all else fails! However, I might go with a new lock cylinder before that . . . .
There is a little piece of pot metal in the column, some call it the tumbler, basically turns the turning of the key into forward movement of the ignition rod. The tumbler is the piece that needs to be lubricated, otherwise it will eventually break on you. Mine has broken twice...last time i replaced it, i lubed it up really good and now i dont have those cold morning sticks and hard-to-turn ignitions.
I have this exact same problem. So this thread is of interest to me.
Funny story actually. I used to be able to start it without any keys. So I got used to leaving them at home for running errands. So I went to the dump one day, and while I was there, suddenly it decides it needs a key, and I had no cell phone. What an awkward conversation that would've been with the guys that worked there.Luckily I got it to start one last time without the key. Now I've needed one ever since.
