02' Black Smoke No Start - Ford Truck Enthusiasts Forums
Old 01-19-2011, 05:10 PM
valiant500hp's Avatar
valiant500hp valiant500hp is offline
valiant500hp is starting off with a positive reputation.
I've got an 02' F-350. As some know, I just put Stage 2 injectors in it from Casserly. Anyway, I was trying to run the tank low since it had about 5 gallons of oil pumped into it. Trip gauge said I had about 30 miles till empty. Left work to go get lunch and while getting on the highway up to speed and it spuddered like it was out of fuel and died. Went and got 8 gallons of fuel. Truck turns over real fast (new batteries) and blows black smoke but won't start.
Glow Plug light comes on. This mean the fuel bowl heater is working or fuse isn't blown?
Fuel pumps out of the fuel bowl. Haven't changed the filter yet, but with it smoking it seems fuel is in the cylinders.
Will a CPS cause it to smoke but not start?
Oil level is good.
Truck is sitting on the side of the road while my dad goes home to get his truck to tow it home.
Any thoughts?
Thanks in advance,
Ryan
Old 01-19-2011, 06:28 PM
F350-6's Avatar
F350-6 F350-6 is offline
F350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputation
Glow plug light staying on usually indicates a problem with a PCM circuit not powering up. Usually we don't see any smoke with this, but sometimes we do.
Start by taking the key out of the ignition and pulling the chip to rule that out. A loose chip can do this. Then try wiggling wiring under the hood including below and behind the 42 pin connector, the ICP harness and the IPR harness. Also try the harness that goes over the top of the front driver shock.
Old 01-19-2011, 06:30 PM
tdpower's Avatar
tdpower tdpower is offline
tdpower is a splendid one to beholdtdpower is a splendid one to beholdtdpower is a splendid one to beholdtdpower is a splendid one to beholdtdpower is a splendid one to beholdtdpower is a splendid one to beholdtdpower is a splendid one to behold
I'm not sure but here is a bump for you.
Old 01-20-2011, 06:27 PM
Thanks for the bump, TD
Well, I went back with my dad to get the truck off the side of the highway. This was after I had already put 8 gallons of diesel in it and it wouldn't start, but blew black smoke.
Anyway, when I got there, I unhooked the ICP sensor and tried to start the truck. It fired up and spuddered and died. Tried again and got it running for about 10 seconds and shut it off. Plugged the ICP sensor back in and it started again. Drove off to a better location and put some more fuel in it. It was missing and coughing a lot, but figure it had air in the system.
On my way home, the truck had no power. It would barely get up to speed and was shuddering quite a bit. Even when I got up to 60 mph it was shuddering. Drove about 30 miles home, stopped at the fuel station, filled up and it was still missing at an idle and shuddering while driving. Got almost home and decided to stand on it. Floored it and it kinda accelerated and I got it up to 75 mph and let out of it. The miss went away.
Got home and changed the fuel filter, it ran fine. Took it for a quick drive and it seemed to drive fine.
Next morning, I started it and it started fine, but was missing again. Got on to the freeway and it was shuddering the entire time I had it on cruise at 70 mph. Decided once again to stand on it and it went away after I took it up to over 80 mph. Now I stand on it and it runs fine.
Is there anything that will cause the truck to miss/shudder, but goes away if you stand on the truck and run it real hard? Really confusing. Could the ICP have been bad which cause the truck to die in the first place?
Old 01-20-2011, 07:03 PM
tdpower's Avatar
Do you know anybody with AE scanner? There are quite a few members in your area that might be willing to help. You could also post in your local chapter.
Old 01-20-2011, 08:24 PM
joegebff's Avatar
joegebff joegebff is offline
Gone Fishin for Mark
joegebff has a great reputation on FTE.joegebff has a great reputation on FTE.joegebff has a great reputation on FTE.joegebff has a great reputation on FTE.
Dont know why it would go away....UVCH comes to my mind.
Old 01-21-2011, 12:28 PM
diesel-fitter-bum01's Avatar
diesel-fitter-bum01 diesel-fitter-bum01 is offline
diesel-fitter-bum01 has a good reputation on FTE.diesel-fitter-bum01 has a good reputation on FTE.
Sounds like it's starving for fuel. Did you get your DP upgraded once you installed your stage two's? Weak fuel pump? Fuel psi? Just throwing out ideas.
no start/no white smoke 967.3zf5 1994.5 - 1997 7.3L Power Stroke Diesel 9 06-19-2016 04:14 PM
Won't start after changing out fuel pump finerant 1994.5 - 1997 7.3L Power Stroke Diesel 8 04-16-2015 12:17 PM
2000 Running rough at idle and smoking under the hood. Zwalters 1999 - 2003 7.3L Power Stroke Diesel 6 10-02-2013 08:09 PM
NEED HELP!! No Start - Just cranks Trailblazed 1999 - 2003 7.3L Power Stroke Diesel 75 09-15-2012 04:44 AM
Oil in Fuel Bowl valiant500hp 1999 - 2003 7.3L Power Stroke Diesel 10 01-14-2011 03:13 AM
Tags
60l, 73l, black, blowing, cps, died, diesel, fuel, glow plug, no start, powerstroke, smoke, start, starving, won't start
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
