2004 Ranger bucks on accelleration going into passing gear (40-55 mph)
Old 01-19-2011, 03:30 PM
flipsk8er5's Avatar
flipsk8er5
flipsk8er5 is offline
I have a 2004 Ranger 3.0 V6. Almost every day on my way into work there is a slightly inclined road with a speed limit of 45. When I come to the road and begin to accellerate it starts bucking when it seems to be trying to shift to a different gear. Sometimes it makes a quick vibration like those white lines you run over when coming to an intersection.
Already replaced Plugs and wires.
Any suggestions??? Thanks!
Old 01-20-2011, 10:53 AM
greenpus's Avatar
greenpus
greenpus is offline
how many miles on the fuel filter? plugged fuel filter will cause this.
if you are on a flat road and floor it, does it shift down smoothly and not buck or does it only do it going up hill?
Old 01-20-2011, 12:25 PM
rickf92592's Avatar
rickf92592
rickf92592 is offline
When's the last time the transmission was serviced?
Old 01-20-2011, 04:15 PM
flipsk8er5's Avatar
flipsk8er5
Just changed the fuel filter also.
Today i noticed it being worse on ice. Meaning more jerky. and I doubt it has ever been serviced. I got the truck around 60k miles and it just hit 80k.
It dont jerk as much on flat ground but yes is still does it time to time. I dont notice it being jerky if i floor it. only when I slowly accellerate in the 40-55 mph range. Its more as if it has to do with when its changing gears or trying to change gears.
It did throw a cylinder 1 missfire code and a new set of spark plugs seemed to fix that.
Old 01-20-2011, 06:49 PM
rickf92592's Avatar
rickf92592
Well, since its probaly past due for a trans service I'd start there.
You're sure not going to hurt it by giving it a fresh filter and fluid.
I wish they put a drain plug on the pans. (Just rebuilt a 4r44e on my daughter's truck and didn't take the time to add a plug, D'oh!)
I change the pan contents every 10,000 miles on my SD and Yukon (had to add the drainplug to that one) which keeps fresh fluid in and doesn't 'shock' the system like a complete flush.
1Reddog
2004 - 2008 F150
03-31-2014 06:48 PM
xcaliber1972
1997-2006 Expedition & Navigator
22
04-18-2011 01:52 PM
GregAlex47
08-13-2009 01:07 AM
dbmartin
07-14-2009 11:42 PM
Boiseflyfisher
01-23-2004 01:13 PM
Quick Reply: 2004 Ranger bucks on accelleration going into passing gear (40-55 mph)
