Check Engine Light P2270 - Ford Truck Enthusiasts Forums
Old 01-19-2011, 03:10 PM
BroncoEx BroncoEx is offline
BroncoEx is starting off with a positive reputation.
Hello all.
2005 v-10 x
Check engine light on... pulling a p2270 code
02 sensor Bank 1 / Sensor 2 signal stuck lean
Where exactly is this sensor on the exhaust?
Old 01-29-2011, 12:59 PM
icecold icecold is offline
icecold is starting off with a positive reputation.
the same thing is going on mine,haven't figured out what o2 it is.
did you get yours fixed?
thanks
pete
Old 01-29-2011, 03:41 PM
Yes, I did fix it. The 2005 V-10 has 3 Ox sensors. There is one on each side of the Y pipe coming off the engine, and the Bank 2 sensor 2 is on the exhaust right behind the Cat converter. It is on the top. Very easy to change.... I hit it with PB Blaster the night before..... then again about 1 hour before removing. You can buy a special socket to remove it, but I just unplugged it from the harness, cut the 4 wires off, and used a 7/8 in socket on a 1/2 drive to remove. Put the new on in with an open end wrench, plugged in harness, and was finished. It will take a couple of run - cooldown cycles for the Check engine light to go out. Purchased the sensor at Advance auto. $63 I believe. Very easy.
Good luck.
05 Navi Codes U0100, P0158, P0345, P0349 rowekmr 1997-2006 Expedition & Navigator 4 02-15-2017 09:26 PM
Can someone decode this? 75Three90 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 3 11-04-2015 10:55 PM
Bank1 Sensor2 Where Is It? a3mariner Escape & Escape Hybrid 5 05-23-2015 04:33 PM
2004 F150 engine timing problem? samthemountainman 2004 - 2008 F150 2 02-18-2012 02:46 PM
Code 2270, need help. tps93ranger 1968-2013 Full Size Vans 0 02-12-2010 12:52 AM
Tags
10, 2007, 2270, 46, code, engine, explorer, f150, ford, ii, montego, obd, p0141, p2270, sensor
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
