2000 expedition heater issues. - Ford Truck Enthusiasts Forums
Old 01-19-2011, 03:14 PM
darkestskydiver darkestskydiver is offline
darkestskydiver is starting off with a positive reputation.
ok i posted in the expo forum but got no responses to help with this issue.
when i turn my heater on, the ac come on instead. it does not matter what position any of the dials are on as soon as i turn the blower on the ac comes on. i do not see anything obviously wrong with the controlls. all the ***** turn as they should nothing is striped. i have the 3 dial controll setup no auto heater controlls at all. and nothing is digital. any help would be apriciated. thank you
Old 01-20-2011, 09:42 AM
Mark Kovalsky's Avatar
Mark Kovalsky Mark Kovalsky is online now
Mark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputation
This is not uncommon. A blend door breaks inside the dash and then you can't change temperature. It cost big bucks to fix with factory parts. I've used Heater Treater to fix several. It's cheaper and works MUCH better than stock.
Auto replacement part, blend door fix, Heat, AC replacement parts
Old 01-22-2011, 08:52 PM
projectSHO89 projectSHO89 is online now
projectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant future
Read FAQs above as an orientation to common problems.
Tags
2000, copy, expedition, expediton, forum, heat, heater, heaters, instructions, problem, problems, treater, turn, working, xlt
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
