CAI on 2001 F250 SD 7.3L
I was directed here from the Super Duty section:
I'm looking for some advice on the intake in my truck. We bought the 2001 F250 7.3L a few years back (it was used) with this current intake installed. The hose that is connected behind the filter, in front of the turbo, seems to be stuck where you add oil to the engine during an oil change.
Engine Bay
Hose Connection
From what I understand, that hose is supposed to go to the crankcase vent, but I don't believe that is it. Is my understanding correct? If so, could someone direct me to the right place to relocate this hose?
I appreciate the feedback.
Engine Bay
Hose Connection
Last edited by andrewjanderson; 01-18-2011 at 06:21 PM. Reason: We purchased the truck used.
That is interesting to say the least. The stock setup has a small 90 degree hose that attaches to the intake from the ccv on the drivers side valve cover. Is that plugged?
A lot of people do the CCV mod. You don't have to do a trap like in this link: https://www.ford-trucks.com/forums/9...done-pics.html
If you live some place that does smog testing you probably can't do that. The downside to the mod is you have stinky vapors and smoke coming from under the truck. You might also consider getting a stock intake and if you wanted a cold air intake go with a AIS setup.
I would love to see a picture from further back on the driver side showing the rest of your CAI. The idea behind what you have is to balance things out. The factory set up vents the crank case valve cover on the driver side up into the intake tube between the filter and the turbo. Attaching a hose to the fill tube also vents the passenger side to the same location so the engine is more evenly balanced (in theory at least). You could remove it and plug the hole if you want and the factory CCV set up is vented into the same tube, or leave it alone.
Welcome to FTE.
Welcome to FTE.
Welcome to FTE.
Welcome to FTE.
That's really what it sounds like, but it could be something completely different, its just that where the hose is stuck down the oil fill tube, there is no fitting on it or anything to create much of a seal.
I appreciate the input. Been learning a ton on these forums.
Welcome to FTE.
Welcome to FTE.
You could remove the hose and plug it off, then leave your oil fill cap off and drive around and it won't cause any loss of power, so that hose is not your problem unless it's not sealed and has been leaking dirt in the fitting for thousands of miles (unlikely in my opinion).
If you're low on power, the first thing to do is check for boost leaks. The big aluminum looking tubes (driver side is covered in foil) are the pipes for the intercooler. There are 6 rubber boots that need to be checked. One on each end of each pipe, then two orange ones where the piece in front of the turbo connects to the engine. There are two hose clamps on each rubber boot that you need to make sure are good and snug. You don't want to tighten them with a lot of muscle, just make sure they feel kind of tight.
Then inspect your up pipes for leaks. Up pipes are the pipes behind the motor that come off the exhaust manifold and go into a collector behind the turbo. If you see any soot stains where the pipes connect to the collector behind the turbo, you have a boost leak in the up pipes.
I'll get another picture from the driver's side. The main point of asking this questions is the fact that when accelerating, I feel a slight loss of power when in the upper half of a gear, and a noise that sounds like air being forced out of a hole, and when I mash it it goes away, as if pressure is pushing up on the hose that is stuck down the oil fill pipe and eventually pushes it up far enough to allow air out.
That could be the exhaust valve operating. There is a flap on the exhaust side of the turbo that opens and closes. You can unplug the solenoid at the front of the turbo pedestal to rule that out.
More Pictures
Here is an image from the driver's side.
Driver's Side
As you can see, the intake goes right over the top of the CCV (I now know where it is...) and I got a picture from under the intake.
CCV
That picture shows that the CCV ports in to the intake. Looking at the CCV hose, it looks like the clamp may be loose, as it was very oily when I looked at it.
That means that it looks like the modification was done in order to balance out both sides by connecting the other hose over to the oil fill tube.
I guess that I am getting pressure loss from somewhere else that is causing my power to drop when in the upper half of a gear.
Driver's Side
CCV
Welcome to FTE.
Welcome to FTE.
close off the holes from the fill tube and the one from the CCV that goes into the intake and see what difference it makes. You are pulling oil vapors and by passing your air filters...
interesting
I do not have any gauges, but I can try checking the boots. Would I need to check both the intake side and the exhaust side of the Turbo for a boost loss?
A little bit of hair spray on the boot contact surfaces after they are clean really helps too.
jagergirll
21
02-04-2012 02:45 AM
Bizzyrne
15
10-21-2011 04:41 AM
