Turbo kit parts/diagram... - Ford Truck Enthusiasts Forums
Old 01-18-2011, 05:30 PM
ManicMike's Avatar
ManicMike ManicMike is offline
ManicMike is starting off with a positive reputation.
Talking Turbo kit parts/diagram...
I'm eventually going to turbo my rig but I can't seem to find like a diagram/breakdown of where all the parts/pipes go.
Any help/pics would be great!
-Mike
Old 01-18-2011, 07:07 PM
87crewdually's Avatar
87crewdually 87crewdually is offline
87crewdually is a name known to all87crewdually is a name known to all87crewdually is a name known to all87crewdually is a name known to all87crewdually is a name known to all87crewdually is a name known to all
-Mike
Since there are over 9 different systems made by more than 3 manufacturers(Banks, ATS, Hypermax, ect...)you need to be specific with what you have or is after.
Old 01-18-2011, 08:48 PM
ManicMike's Avatar
Quote:
Jeez, didn't know there was that many! I was just trying to get a general idea of how the system's are ran, I think hypermax is different then the others.
If anything, I'm interested in the ATS systems.
Old 01-18-2011, 08:55 PM
O.k. now we are getting somewhere!
ATS 093 Wastegate System
Old 01-19-2011, 02:15 PM
NorthernDiesel's Avatar
NorthernDiesel NorthernDiesel is offline
NorthernDiesel is starting off with a positive reputation.
Here's a link to the Ford manual on the factory turbo setup for 93/94's
7.3L IDI 93-94 Turbocharged Diesel Engine
Be patient, the file is ~28MB, but its worth it. Great pictures.
Old 01-19-2011, 06:40 PM
Dave Sponaugle's Avatar
Dave Sponaugle Dave Sponaugle is offline
Dave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to behold
In a nut shell the exhaust gases are routed up to the turbo, through the hot side turbine and then back down the down pipe to the exhaust.
The hot side turbine shaft turns the intake side (cold side) turbine which draws air in through the air cleaner, compresses it and blows it into the intake.
The only other thing you need is an oil supply to the turbo and a way to get the oil to drain back into the engine.
The exact way each system does the above is slightly different, but that is a turbo system in simple terms.
Old 01-19-2011, 06:43 PM
The correct term for the charge side is compressor, and the hot side is the turbine.
Need wiring diagram for halogen taillights turbo06 2015+ F150 2 08-22-2015 05:05 PM
Wiring diagrams and as built data turbo06 2015+ F150 3 08-11-2015 01:30 PM
97/ 7.3 turbo removal Asytole61 1994.5 - 1997 7.3L Power Stroke Diesel 13 12-03-2014 12:04 AM
Wastegate diagram Crewcab Turbo 1999 - 2003 7.3L Power Stroke Diesel 3 08-30-2011 09:42 AM
Parts diagram ReAX Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 1 07-31-2006 09:24 PM
Tags
73, 73l, 94, banks, break, charger, diagram, diesel, engine, idi, parts, powerstroke, rig, setup, truck, turbo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
