CAI on 2001 F250 SD 7.3L
I'm looking for some advice on the intake in my truck. We bought the 2001 F250 7.3L a few years back (it was used) with this current intake installed. The hose that is connected behind the filter, in front of the turbo, seems to be stuck where you add oil to the engine during an oil change.
Engine Bay
Hose Connection
From what I understand, that hose is supposed to go to the crankcase vent, but I don't believe that is it. Is my understanding correct? If so, could someone direct me to the right place to relocate this hose?
I appreciate the feedback.
Engine Bay
Hose Connection
Last edited by andrewjanderson; 01-18-2011 at 06:20 PM. Reason: We purchased the truck used.
I am going to check to see if I can find the CCV and check for a plug. Looks like I"ll also need a replacement cap for the oil fill.
Yes you'll need a new oil cap, make sure the hole in the intake tube where they routed that hose to is plugged up tight then you can face the doghouse rearward and run a hose from it over the master cylinder and down to the framerail for a nice clean CCV.
Teamrope
02-12-2011 01:06 PM
andrewjanderson
01-23-2011 01:43 PM
