Injector buzz test and some questions
Old 01-17-2011, 10:02 PM
dyoung14's Avatar
dyoung14
dyoung14 is offline
I been battling an intermidiate miss, i thought i killed it but it came back.
So today i took it to my buddy and we put a code reader on it, only code it brought up was something about the <ACRONYM title="Injection Control Pressure">ICP</ACRONYM> sensor and the <ACRONYM title="Exhaust Back Pressure Valve">EBPV</ACRONYM> sensor, the <ACRONYM title="Exhaust Back Pressure Valve">EBPV</ACRONYM> is on a toggle, and the <ACRONYM title="Injection Control Pressure">ICP</ACRONYM> was were i was playin with resistors, but i tookk them out before we put it on the reader, after we cleared the codes that one didnt come back up,
So then we run an injector buzz test, they all sounded good up until the 7th one that buzzed it has a lower sound than all the rest. we ran the test again this time with my hands on the valve cover and felt of it and the one that has the different sound feels like the 1st injector on the passenger side of the engine,
Now the problem im having is that idle has a slight miss and it gets kinda bad at 2500 rpm and blows blue smoke, then when it passes 2800-3000 it will clear up and run like mad to the govenor.
My buddy is supose to come over later and bring a couple more readers and were gonna play around with it somemore, so what do yall think? weak injector?
<!-- / message --><!-- sig -->__________________
David
Old 01-18-2011, 12:03 AM
Talyn's Avatar
Talyn
Talyn is offline
You'll have to take the VC's off for one.
So if your garage is heated, get them off before you play around.
You can run the truck with the VC's off, its not messy.
number 7 is back by the firewall on drivers side.
With the VC's off you can check all the connections.
It, hopefully, is just a burnt UVCH.
Old 01-18-2011, 07:10 AM
dyoung14's Avatar
dyoung14
dyoung14 is offline
I dont think it is the 7th cylinder, its just the 7th one it made buzz. i had my hands on the valve covers it felt like the 1st injector on the passesnger side
Old 01-18-2011, 11:23 AM
Talyn's Avatar
Talyn
Talyn is offline
They buzz in fireing order.
They all buzz at once, then they fire off in order.
Old 01-18-2011, 08:31 PM
dyoung14's Avatar
dyoung14
dyoung14 is offline
Ok so which one is the 7th one that buzzed?
Old 01-18-2011, 08:55 PM
fordpride's Avatar
fordpride
fordpride is offline
the frist buzz you hear should be louder then all the other buzz then they will buzz in order 1-2-3-4-5-6-7-8
So the 7th buzz you hear should be injector 6
Old 01-18-2011, 08:57 PM
fordpride's Avatar
fordpride
someone correct me if i'm wrong
Old 01-19-2011, 01:19 PM
Talyn's Avatar
Talyn
Talyn is offline
Sorry, I was taking into the assumption that he was speaking about the individual buzzes.
firing order on buzz test is 1-8 yes.
injector 6 is. second to last towards the firewall on Drivers side.
injector 7 is the last on the Passenger side.
Ooops.
I got em backwards before.
With the strange way they count the cylinders on our truck, it gets confusing.
1 3 6 7 are pass side, and 2 4 6 8 are drivers side.
Old 01-22-2011, 12:29 AM
johnbrown's Avatar
johnbrown
johnbrown is offline
Hi, i had a buzz test done on my 95psd,one injector was not quite right,but have followed up yet was told that you could buy the solenoid on top of the injector for about $57 on
ebay,has anyone tried this yet,thank's
Old 01-22-2011, 08:07 AM
Quadzilla's Avatar
Quadzilla
Quadzilla is offline
This=http://www.dieselpro.ca/Poppet%20Valve.pdf might be worth checking out.
Old 01-22-2011, 11:24 AM
Talyn's Avatar
Talyn
Talyn is offline
if your having funny sounds during a buzz test it is not because of a bad solenoid.
It is most likely poppet issues. When the poppet clearance is off due to worn injectors, the poppet cannot be picked up by the solenoid properly because its further away, thus a different sound, or a "weaker" sound which would make you think the solenoid was bad.
Generally means your ready to have your injectors rebuilt and re-clearances.
Hence one of the reasons DIY Kits were taken off the market.
People would have issues, buy a DIY kit, and the problem would still be there because the tolerances were not put back into spec.
Send our site sponsor, Jim, an email. Rosewood Diesel Shop <sales@rosewooddieselshop.com>
Jim is a great guy and can tell you all about it. Even though he'll tell you the same thing I just said.
Solenoids rarely go bad. He can tell you how many bad solenoids in the hundreds of injectors he's built were bad. I'm pretty sure he can count them on 1 or both hands still.
If you have issues with solenoids firing and your injectors are good. Start swapping harnesses around and checking/cleaning a connections.
Use some Conductive Grease in there as well if you need too.
countrycar
11-21-2012 07:16 PM
cyco
09-24-2012 09:53 AM
THEDON117
30
10-06-2011 11:28 AM
strokin'_tatsch
27
04-03-2010 06:39 AM
strokin'_tatsch
96
03-03-2010 09:01 AM
Quick Reply: Injector buzz test and some questions
