fuel filter gasket leak / low fuel
I've run my truck way low on fuel a few times over the last years, and almost each time thereafter, I sprung a fuel leak from the filter gasket after I re-filled her. Each time I also replaced the filter and gasket, but this time I still have a leak. I brake cleaned and gunked around the fuel bowl, the drain, and in the valley, but I still get a drip down the rear of the block. Is there any other place I can hunt for a leak, or am I replacing the fuel bowl gaskets again. Also, is now the right time for e fuel bowl delete?
It could be that your drain valve is leaking.
What fuel filters are you using? Are they the factory filter with a separate cap or the kind with a built in cap?
I use the OEM style and the factory cap. I have never had a problem sealing them from leaking. I do coat the wedge shaped seal with a thin coat of clean oil, this keeps them from pinching when tightened down. Also many times everyone thinks they need to be really tight. An o-ring type seal can actually be damaged if over torqued.
woodnthings has you taken care of. If you do indeed need the drain o rings, Bob at dieselorings can get you some flourosilicone rings which are MIL SPEC and top notch quality. The ULSD fuel the gov't mandated a few yrs back seems to dry some of the o rings out faster. The flouro-x type are very tolerant of tough environments
DasKroger
09-30-2010 02:37 PM
joe Kikiwai
02-02-2006 02:57 AM
