Advice on replacing oil pressure sending unit - V10
Have the common problem of the oil pressure gauge reading 0 when cold - done it for the last 3 years, and am finally going to replace it. Anyone ever done it? Never done one before, any advice would be great. Do you just screw it in, or do you put something on the threads? Any location advice? Thanks in advance.
It is located on the driver side of the motor, just below and in front of the head/exhaust manifold. (in the block, not the head I think, lower, toward the pan) It has a single pin connector. Torque to 10 ftlb. Book time is under .5 so it should not be too hard.
I have never done this so this info is from the manuals. It looks like the sensor is located just under a coolant line that exits the motor in the same area but I can not tell for sure from the diagrams.
Kneetoe
08-29-2016 04:46 PM
countrydriven
15
08-02-2016 07:49 AM
IronHorseDriver
1983 - 2012 Ranger & B-Series
10-02-2015 12:01 AM
Tylers
13
07-29-2009 12:06 AM
