How many mpg's are u guys getting in 5.4 superduty - Page 6 - Ford Truck Enthusiasts Forums
  #76
Old 11-13-2011, 07:07 PM
fordfarmer12 fordfarmer12 is offline
fordfarmer12 is starting off with a positive reputation.
Quote:
Originally Posted by NOLA Blake View Post
I have a '03 f350 5.4 4x4 crew cab long bed. 98k miles. All stock except for K&N filter and Predator tuner. The tuner woke this truck up so much that it does not even seem to be the same truck. Much better throttle response. I went on a 180 mile one way trip to buy a utility work top for my truck. On the way there I got 17.6 mpg. With the top on I got 13 on the way back. Definetly need to take the top off for trips! Tuner was worth every penny ($169). I think the truck was getting around 10-11 before i installed it.
Where did you get that tuner?
  #77
Old 11-14-2011, 07:25 AM
NOLA Blake NOLA Blake is offline
NOLA Blake is starting off with a positive reputation.
Predator Tuner
I just checked my old emails and found it. I messed up on the price.. it was 269.00. I bought it from 4wheelonline.com. I have not customized anything on it. I just used the 87 octane setting and man did it make a difference! I bought this truck from a friend of mine and just figured that the motor was too small for the weight of the truck. When you put the accelerator to the floor it felt like you were taking on in 2nd gear. Now it jumps whne you hit it. Mileage really impressed me. My friend got the same tuner for his 2010 Silverado and he can barely notice a difference. I guess my truck was just not right from the factory.
I have to say I was hoping for more features on the tuner, but I think I got my moneys worth with performance and mileage.
  #78
Old 11-15-2011, 04:33 PM
TheStuffz's Avatar
TheStuffz TheStuffz is offline
TheStuffz is gaining momentum as a positive member of FTE.TheStuffz is gaining momentum as a positive member of FTE.
Father has a 06 250 SD and a 07 350 SD both with the 5.4 and they get 7mpg highway... even worse towing. fully tuned up and new injectors, plug packs, plugs, filters etc.
  #79
Old 11-18-2011, 09:09 PM
SDTriton250 SDTriton250 is offline
SDTriton250 is gaining momentum as a positive member of FTE.SDTriton250 is gaining momentum as a positive member of FTE.
7mpg? Dang! I get 8.5~mpg towing our 8500~lb 5th wheel 65mph. Something is bad wrong with those trucks.
  #80
Old 12-27-2011, 08:00 PM
BrockwayMT BrockwayMT is offline
BrockwayMT is starting off with a positive reputation.
09 reg cab with flatbed 3.73 4x4 M6
13 mpg mixed driving on winter gas
14-15 mixed in summer
17 with pickup box on the highway at 72, haven't taken a long highway trip with the flatbed
  #81
Old 02-10-2012, 11:17 AM
jlheine's Avatar
jlheine jlheine is offline
jlheine is starting off with a positive reputation.
2000 with a 5 speed, lifted 10 inches on 40's, 4.88 gears and i get 7-8 city, 9-10, sometimes more highway. a little engine work, but not much.
  #82
Old 02-18-2012, 05:41 PM
L Parker L Parker is offline
L Parker is starting off with a positive reputation.
mpg'sss?
Reading these coments makes me wonder, why the big differences? But may be it's a Ford thing. We owned a low mileage ( 45t orig in 99 when we bought it) '83' F-250 XLT 2wd, that was a great truck, the heavier you loaded it the better the mpgs got. Empty maybe 8 or 9, put 50 bales of hay in the bed and get 10 to 10.5, hook on what we affectionatly called the giant red box, a 23 foot draft horse trailer with living area and add two 1000 lb AQHA mares and the milage went to 13.8 to 14.9. Needless to say really miss that truck. Now own a '08' SD 2wd basically same truck but younger and higher milage, and it gets 10 to 11.9 town unloaded, and we just drove it 3000 miles with a truck cap and load of belongings and got up to 16.9 mpgs.
  #83
Old 03-29-2012, 07:02 PM
timellis timellis is offline
timellis is starting off with a positive reputation.
L Parker, you can't REALLY believe that can you? I mean come on, 8-9 empty and almost 15 towing? I think some people don't realize what a difference in mileage you will see{incorrectly} when you check mileage by where the gauge needle is, or by fueling up after a short trip. The only correct way to know for sure is to fill the tank, then use almost the whole tank and refill it to FULL the same way each time. If you try to drive 20 miles and refill you can get a variance of as much as a a gallon or so of how much fuel it takes, depending on how it is filled, where, how level, temp. outside.... A gallon in 20 miles is a big mileage changer versus a gallon in a 29 gallon fill, and 400 miles. Not trying to be rude , just sayin...
  #84
Old 03-31-2012, 04:29 PM
david von wald david von wald is offline
david von wald is starting off with a positive reputation.
2000 f-350 6.8 V10
9-11 mpg empty or fully loaded
  #85
Old 03-31-2012, 06:14 PM
hojolabo's Avatar
hojolabo hojolabo is offline
hojolabo is starting off with a positive reputation.
Mine is a 2003 5.4 HD F150 FX4 with the tow package, my wifes & my suit cases & toneau cover, 20.2 highway not exceeding 65 mph and outdoor temp 65 deg. This is the best I've got along with the slowest I've drove on a trip.
  #86
Old 03-31-2012, 06:18 PM
acf6's Avatar
acf6 acf6 is offline
acf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputation
Filled up yesterday and got 11.3 , about 75/25 city/highway
  #87
Old 04-02-2012, 12:14 PM
Just filled up the other day and got 11.4 in my 05 250 5.4. Lots of country driving with maybe 30-40% highway. I get up into 5th gear as quickly as I can and hold there.
  #88
Old 04-04-2012, 11:02 AM
Ohiocrewcab's Avatar
Ohiocrewcab Ohiocrewcab is offline
Ohiocrewcab is gaining momentum as a positive member of FTE.
Hey guys I'm from the dent-side side of things. I'm looking into stepping up and getting a newer truck. The one I'm looking at is a 02 F250 crew cab long bed with the 5.4 and an auto and 4x4 with 70k on the drivetrain. What kind of mileage can I expect? From what I've read I'm looking about 10-12 for an averag. Any insight in this new creature would be great.
  #89
Old 04-04-2012, 05:03 PM
acf6's Avatar
Youre in the right thread lol..
  #90
Old 04-08-2012, 09:59 PM
Yeah I would say that for a truck like that 10-12 MPG is a pretty good estimate when you're empty. Gotta love the power of a Ford though, that's why I put up with the not-so-fantastic fuel mileage.
2013 Ecoboost 14.0 mpg...disappointing? (3.73, leveling kit, 34" tires) bridomine99 2009 - 2014 F150 19 11-09-2014 05:34 PM
My V10 MPG Analysis (long…bring a drink) onug Modular V10 (6.8l) 23 06-10-2012 11:10 PM
11MPG on 6.0 PSD EX amyd091 Excursion - King of SUVs 20 01-07-2011 12:00 PM
MPG difference w/ lift & 37" tires?? BuCKxWiLD 1999 to 2016 Super Duty 5 02-28-2006 01:21 AM
Can the fuel mileage get any worse? afrantom 6.0L Power Stroke Diesel 25 01-17-2005 09:47 PM
Tags
04, 2002, 2008, 54, 54l, duty, f250, f350, ford, gallon, miles, mpg, runs, super, superduty, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
