How many mpg's are u guys getting in 5.4 superduty - Page 4 - Ford Truck Enthusiasts Forums
  #46
Old 05-13-2011, 10:09 PM
Johnny Langton's Avatar
Johnny Langton Johnny Langton is offline
Johnny Langton has a great reputation on FTE.Johnny Langton has a great reputation on FTE.Johnny Langton has a great reputation on FTE.Johnny Langton has a great reputation on FTE.Johnny Langton has a great reputation on FTE.Johnny Langton has a great reputation on FTE.
Quote:
Originally Posted by Jasonec83 View Post
Thanks Johnny for the feedback. You said you fabricated one for your navigator; did you use one fan or two? Also, did you build a shroud for the fan(s) or did you just bolt them on the back/front of the radiator?
If youíre willing to show off your work with some pictures that would be of great help to me.
What kind of increase in power and/or mileage did you notice?
when the fans kick on do you notice any draw on the electrical system? Your dash lights don't dim or anything do they?
Flex-a-lite sells a two fan bolt on kit for the f-250 that claims to move 4000cfm, but it does not use a shroud. Iím thinking that kit would be a good starting point but before I bet 600$ that it will work I would like to get as much information as possible.
I used an OEM '94-'97 Tbird 2 speed fan.
I attached it to the OEM truck fan shroud to keep a good flow of air through the radiator. The Tbird uses a 130 amp alternator-the same alternator that the Navigator uses. Power gains are minimal, mileage gained was 1.5-2 mpg consistently. I've heard OF nothing but problems out of that flex-a-lite "kit". The fan controller that is included with that "kit" commonly fails.
JL
  #47
Old 05-14-2011, 07:26 AM
EXCURSIONATOR1's Avatar
EXCURSIONATOR1 EXCURSIONATOR1 is offline
EXCURSIONATOR1 is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by Johnny Langton View Post
What brand and type?
JL
It is a procomp 16 inch fan with a thermostat that pokes into the radiator fins. Fan wasn't big enough I know I just went electric in the winter months to offset the worse gas mileage it was getting due to the cold.
Electric fans do help with gas mileage for sure.A close guess would be 1 mpg highway and 2 mpg around town
  #48
Old 05-14-2011, 01:56 PM
Jasonec83 Jasonec83 is offline
Jasonec83 is starting off with a positive reputation.
Thanks for the tip Johnny. the thunderbird fan looks great and the shroud is 18.5x22. I think that should cover most of the radiator. Oh yeah best part is you can by it for 59.99 on farnconversion.com. The relay is 17.99 with shiping this works out to right around 100$ project. I made a spreadsheet to caslculate the fuel savings. Assuming I get a 2mpg increase for 100$+elbow grease this project will pay for itself around 2500 miles down the road.
I was going to ask if there was a particular fan controler setup you perfered?
the last thing I need is to have this thing not work when my wife is driving it.
  #49
Old 05-14-2011, 02:00 PM
Anyone tried running camper shells or toneau covers to increase mileage?
  #50
Old 05-14-2011, 02:50 PM
That's why you had issues with the fan in warmer weather. Those aftermarket fans do not have enough motor power and a poor fan blade design to keep the small motors from burning up trying to turn them. The result is a weak airflow that does not cool efficiently.
OEM fans are built for 100K mile durability, have much better designed fan blades,and have larger motors that can move the air needed for cooling in even 100+ degree days.
I used a Derale brand adjustable fan controller.
Derale Cooling Products 16749 - Derale Performance Deluxe Adjustable Controllers with Pipe Threaded Probes - Overview - SummitRacing.com
One good thing is that you can wire this controller to fire up the fan when the A/C compressor is on for good cooling. This controller was wired to trigger a high current relay that can handle the amp draw of the Tbird fan. It WILL MELT the 30/40A cube type relays that they are showing on that fanconversion.com . DO NOT use one of those-it WILL fail, and leave you stranded.
This is the relay type you need:
BOSCH TYCO RELAY 75 AMP 12V HEAVY DUTY HIGH CURRENT | eBay
JL
  #51
Old 05-14-2011, 04:14 PM
Beechkid Beechkid is offline
Beechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud of
If any of you guys know where I can find the answers to any of these questions I would really appreciate it.
Thanks,
How many CFM does the stock fan move?
Any suggestions about using OEM fans off of other vehicles or fans that may be used for other purposes than automotive?
Any suggestions on ways to build the shroud itself?
Plastic?
Fiberglass?
Sheet metal?
I have used flex a lite befor and serveal others and found, well, their cfm ratings are, well.....crap.
The oem units (police crown vics, mark VIII, lat model Cougar V8) all are smaller, much more efficient than anything I have seen, tried in the aftermarket (performance) world. I recently had to relace the entire fan/schroud assembly in our 1997 cougar sport (V8), the oem replacement unit complet was $90 includng tax.
  #52
Old 05-14-2011, 06:33 PM
acf6's Avatar
acf6 acf6 is online now
acf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputation
i had a tonneau but it didnt really do anything except on long highway trips (which i rarely do) so i just took it off a bought a tool box.
  #53
Old 05-14-2011, 10:43 PM
I'm going to hit victory auto wreckers. I Hate that whiring sound of a mechanical fan! Also throttle response has changed.
  #54
Old 05-17-2011, 03:58 PM
2002Ford5.4L-SD 2002Ford5.4L-SD is offline
2002Ford5.4L-SD is starting off with a positive reputation.
I'm getting about 11 mpg.
  #55
Old 05-17-2011, 04:05 PM
acf6's Avatar
<a href="http://www.fuelly.com/driver/acfirecat6/f250-super-duty" target="_blank"><img src="http://www.fuelly.com/sig-us/50329.png" width="500" height="63" alt="Fuelly" title="Share and compare MPG at Fuelly" border="0"/></a>
  #56
Old 05-17-2011, 04:58 PM
Huntersbo Huntersbo is offline
Huntersbo is starting off with a positive reputation.
Not a superduty but still a 5.4L. '05 F-150 5.4L 3V two-wheel drive ex-cab 6.5'bed, 3.55:1 gears, 30.25" tires, premium-tune, custom y-pipe, 3" single exhaust. 10.5 city and 16 mpg on a long interstate trip once. It generally falls between 10.5 and 13 mpg mixed driving.
  #57
Old 05-20-2011, 07:14 AM
03_superduty 03_superduty is offline
03_superduty is starting off with a positive reputation.
I have an 03 5.4l with auto 102xxx and Im getting 11.5-12 all the time. Ihave an 8" BDS lift with 37x13.5x16..... I have 4.56yukons, k&n cold air, diablo tuner w/ custom tune. I just filled it up this morning and got 11.6 mpg so i cant really complain
  #58
Old 05-21-2011, 07:52 AM
Clutch47 Clutch47 is offline
Clutch47 is gaining momentum as a positive member of FTE.
MPG's...and driving style...
Fellas,
03 SD tow pkg...reg cab 8' box.. 5.4L ..13K miles on Grooms crate motor..w/JBA headers..still on original exhaust...285/75-16's and 3.73's....
Drove to Nashville from PA and got 15.9 on the highway with no tailgate and mirrors folded in..Threw a Husaberg dirt bike in the back that I bought down there, folded the mirrors out, and put the pedal down a bit coming back...and got 17.1...uphill..
I don't get it !!! Must be the bike sticking up above the cab a little helped with the airflow or something...
.........................Clutch47................. .........................
  #59
Old 05-21-2011, 10:01 AM
SilverE350's Avatar
SilverE350 SilverE350 is offline
SilverE350 is starting off with a positive reputation.
Clutch: A couple of tankfulls better or worse really doesn't tell you much. Fuel economy needs to be measured over thousands of miles to be accurate. Still, averaging 16 give or take, like you did is pretty good.
  #60
Old 05-30-2011, 02:42 PM
MSgtZ MSgtZ is offline
MSgtZ is starting off with a positive reputation.
Ok I just got my 05 F250 4x4 late last week and have only had a chance to run one tank through it, but for kind of around town driving I do here in southern Maryland this first tank was 14 MPG. My old 98 F150 4x4 was only getting me 16 MPG for the same type of driving (and it had the 4.2L V6 and 3.55 gears).
Truck details are 2005 F-250 Super Duty Crew Cab 4x4, 5.4L, 3.73 LS, Torqushift Auto, LT285/70-17 tires, ESOF transfer case. 51K when I got.
My old 87 F250 super cab with the 6.9L diesel has blown a combustion chamber (needing head work) after 300K+ miles and the condition of the body, trans and rear end just made it too expensive to fix (I have done all the work on this truck for the last 15+ years) even with me doing all but the machine shop work. It is just too rusty and too worn out finally. The 98 F-150 was my dads truck from new, but being it was from New England everything under the hood and body is a mass of rust. Working on it is (now was) an exercise in flustration with broken/rusted bolts etc .
So hopefully this 05 will be as good as my 87 was (I am really going to miss that truck), minus the fact it is not a diesel. Fuel mileage of this new truck sucks compared to the old diesel but is not bad compared to the F-150. That F-150 can really eat the gas when towing (it has only ever towed my utility trailer with my motorcycle on it, this is a faily light setup of less than 1500lbs) even at 60mph. I will provide an update once I get a chance to put some miles on it.
360 in my 72 250 gas mileage question Bullseye72 1967 - 1972 F-100 & Larger F-Series Trucks 17 12-16-2014 11:24 AM
What's your mpg on the v8 5.4? bronco6767 1999 to 2016 Super Duty 26 11-25-2014 12:30 PM
2013 Ecoboost 14.0 mpg...disappointing? (3.73, leveling kit, 34" tires) bridomine99 2009 - 2014 F150 19 11-09-2014 04:34 PM
Honeymoons Over Report jakeharp 2009 - 2014 F150 16 01-01-2014 01:14 AM
Real world diesel MPGs jl429 General Diesel Discussion 6 09-19-2013 05:13 PM
Tags
04, 2002, 2008, 54, 54l, duty, f250, f350, ford, gallon, miles, mpg, runs, super, superduty, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
