How many mpg's are u guys getting in 5.4 superduty - Page 2 - Ford Truck Enthusiasts Forums
Old 01-24-2011, 02:27 PM
bigblue61's Avatar
bigblue61 bigblue61 is offline
bigblue61 is starting off with a positive reputation.
Theres too many factors, my engine is in near perfect condition just changed the plugs out and i get about 11.5 and much less in the winter. But I idle alot and have a lot of short trips and sometimes my truck dosnt warm all the way up. If you do a lot of highway driving or dont drive as hard or dont idle as much your v10 numbers could be better. Theres just no way to compare numbers that arent done close to the same way.
Old 01-24-2011, 02:33 PM
Johnny Langton's Avatar
Johnny Langton Johnny Langton is offline
Johnny Langton has a great reputation on FTE.Johnny Langton has a great reputation on FTE.Johnny Langton has a great reputation on FTE.Johnny Langton has a great reputation on FTE.Johnny Langton has a great reputation on FTE.Johnny Langton has a great reputation on FTE.
Quote:
This is exactly right.
I know that I drive exactly the same as a good friend of mine that's nearby, our trucks are equipped almost exactly the same, we both feel the same about warmups,etc,etc..and his 5.4L truck is the same towing a similar load, and only 1-2 mpg better highway driving.
JL
Old 01-24-2011, 03:42 PM
bigblue61's Avatar
about 1-2 sounds about right especially when were talking about ranges from 11-14mpg thats a difference of anywhere from 10-19% in fuel econonmy between the two motors.
Old 01-26-2011, 09:52 PM
brd7666's Avatar
brd7666 brd7666 is offline
brd7666 has a very good reputation on FTE.brd7666 has a very good reputation on FTE.brd7666 has a very good reputation on FTE.
I get about 12 mpg on the highway. I usually cruise between 75 and 85 mph.
Old 01-27-2011, 08:16 PM
REXHOUND REXHOUND is offline
REXHOUND is starting off with a positive reputation.
11 city and 16 highway
Old 01-31-2011, 08:49 PM
SilverE350's Avatar
SilverE350 SilverE350 is offline
SilverE350 is starting off with a positive reputation.
2008, 5.4, 2 valve, E350 SD. Vancouver BC to L.A. 65-70, mostly 70 MPH.
13.5 MPG
(yes that's US gallons)
Old 02-16-2011, 04:34 PM
faster's Avatar
faster faster is offline
faster is starting off with a positive reputation.
Quote:
Originally Posted by Johnny Langton View Post
Wow, just wow.
You guys need to look at your fuel sources, condition of the engine, tuneup, etc..something's definitely not right.
What you guys are talking about for fuel economy, is what my V10 F250 and V10 Excursion get regularly.
JL
Hey I screwed up lesseon learned. I'll get the V-10 next time.
My 97 150 5.4 with 3.55 gears and 255X70X15 tires, 2wd gets 12-13 city full of tools and 17-18 hwy with 190K miles on it. But only 7-9 towing the horse trailer.
My 03 250 5.4 with 3.73 gears and 315X75X16 tires 4X4 gets 11-13 everywhere empty but 14-14.5 over 75 mph. But towing the same horse trailer gets 11-12, go figure.
I figured it would be less than the 150 but not that much.
Anyway next time it's a V-10 unless Ford makes a diesel I can work on without pulling the cab off, friggin idiots. I'm thinking about taking the 5.4 and trans out of the 250 and transplanting it into the 150 and put a Cummins in my 250 and send FORD the pics just **** them off.
Mikey
Old 02-16-2011, 08:27 PM
bigblue61's Avatar
you get 14.5 and your complaining, thats the high end of what i get and I am not running 35 inch tires. I don't know how you can expect your 3/4 ton to get close to your half ton when your running wider, taller heavier tires on a 4x4 compared to a 4x2. Not to mention a super duty has a higher curb weight. Of course its going to be less significantly less.
Old 02-17-2011, 11:30 AM
faster's Avatar
I'm not complaining at all just relating what I'm getting. I still haven't figured out why it goes up over 70mph, must be coming up on a sweet spot on the cam.
Now if you really want to hear whining here goes;
I have a 625 horsepower at the crank high 10 second 3600# street car that gets 17 city and 25 hwy with an overdrive trans.
There are guys cruising the streets in 55-57 Chevy shoe boxes that weigh 2 tons have 650-700+ inch motors making 1600-1800 horsepower running high 6's at 200+mph getting 15 cty 25 hwy mpg towing a small trailer around to the events and tires a whole lot bigger than mine.
The technology is out there and I'm just getting started with it. I'll get my F250SD with a gas motor to make 400 crank horspower and 450 ft.lbs. of torque and still get 20+ mpg average. I will then tell you how to do it.
The technology has been out there for almost a decade and the car companies are still in bed with the petroleum companies screwing us.
25+ years ago Popular Science published Smokey Unich's report of taking a 2.2 liter Chrysler four cylinder and getting 345 reliable horsepower at 45 mpg on pump gas. He was just scratching the surface and Chrysler then proceeded to kill it. God only knows what could be done with a diesel.
Google alcohol fuel and read the reports coming out of the top engineering schools for the last decade. 30% better fuel mileage and 30% more power from alky on engines specifically designed to run alky with no power adders. Add superchaging/turbocharging and the sky's the limit These flex fuel engines are a joke. You can make 4-5 liters of alky in your garage for $1.25/gallon/day with an old 30 gallon hot water tank.
Again we're getting hosed!!!!!!!!!!!!!!!!!!!!!!!!!!
Okay I'll get off my soapbox now
Mikey
Old 02-17-2011, 02:11 PM
Mikey
Here you go....you left this at home this morning:
JL
Old 02-17-2011, 02:48 PM
dkf's Avatar
dkf dkf is offline
dkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to behold
I needed a good midday laugh faster. Glad I checked this thread.
Old 02-21-2011, 02:54 AM
kengoff's Avatar
kengoff kengoff is offline
kengoff is starting off with a positive reputation.
Thumbs down poor gas mileage
2004 F250 5.4 auto 9.2-9.3 mpg to work and back less than 10.8 interstate. Mileage was this poor then new, Service depart. says "it will get better after the motor breaks in "then after 30k they say "thats just the way it is".
  #28
Old 02-21-2011, 03:00 PM
EXCURSIONATOR1's Avatar
EXCURSIONATOR1 EXCURSIONATOR1 is offline
EXCURSIONATOR1 is gaining momentum as a positive member of FTE.
Kengoff with that kind of gas mileage I'm suprised you don't see a trail of black smoke behind you on the highway.
My excursion at 80mph into a headwind gets 10! With moderate temps. I can get 16-17 at 67mph. 5.4 v8
  #29
Old 02-22-2011, 12:45 PM
Downsea's Avatar
Downsea Downsea is offline
Downsea is gaining momentum as a positive member of FTE.
Quote:
Same boat Kengoff, 9 to 10. 4x4 for very long and it's down to 8. Half tank of gas for 110 mile highway run at 65mph. I swear all I have to do is look at it and the needle goes down.
  #30
Old 02-22-2011, 01:37 PM
Jakegrape Jakegrape is offline
Jakegrape is starting off with a positive reputation.
in my 04 super duty xlt 5.4 im getting about 13mpg in town and around 14.5 - 15 highway. I grandpa the snot out of it though, rarely EVER allowing for more than 2k rpms.
2013 Ecoboost 14.0 mpg...disappointing? (3.73, leveling kit, 34" tires) bridomine99 2009 - 2014 F150 19 11-09-2014 05:34 PM
My V10 MPG Analysis (long…bring a drink) onug Modular V10 (6.8l) 23 06-10-2012 11:10 PM
11MPG on 6.0 PSD EX amyd091 Excursion - King of SUVs 20 01-07-2011 12:00 PM
MPG difference w/ lift & 37" tires?? BuCKxWiLD 1999 to 2016 Super Duty 5 02-28-2006 01:21 AM
Can the fuel mileage get any worse? afrantom 6.0L Power Stroke Diesel 25 01-17-2005 09:47 PM
Tags
04, 2002, 2008, 54, 54l, duty, f250, f350, ford, gallon, miles, mpg, runs, super, superduty, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
