51 Ford F-6 COE help!
I was wanting to go with a cummins. I have found a few trucks. The main one I am looking at is a 96 dodge 2500 STD cab 2wd long bed. I was a heavy equipment mechanic in the military. So I know my way around diesels and fabricating. I just never took on a task like this. I want to keep the body stock looking but with a nice cummins under the hood and updated suspension.
I have started to strip your old one down for spare parts. i hate the idea of some of those things like the brake drums and transmissions going to scrap. Even if I don't need them, there are sure to be others that do.
on
Quote:
Originally Posted by 76f350spercamprspeal
Welcome to FTE, Best Damn Forum EVER!
Here's How to Post Pictures:
1. Login to FTE.
2.Click User CP (In the Top Left Hand Corner)
3.(On the Left, There will be a list, The 5th Option Down, will say "Pictures & Albums) Click That.
4.Then, Click Add Album, Enter a title, and description, if ya want to.
5. Click Upload Pictures, Then click Browse, Locate the Files of your truck. (You can add 3 files at a time)
5. Click Upload.
6. Add a description to the individual pictures, then click save.
7. Add more files if ya want.
8. Click The Picture you want to post, it will give you two codes at the bottom, Right Click The Second one (It say's BB Code, Then Say's [IMG]http:blahblahblah...[/IMG])
Then, Once that is highlighted, Right Click, Then Copy, Then Paste it into your post.
You can add up to 30 Images in one FTE Post.
If, Ya need any help, Don't hesitate to ask.
1. Login to FTE.
5. Click Upload.
After I finish the truck bed, I will have more time available, that's when I would like to pull it back up to the barn and remove the engine & transmission. The motor isn't stuck, but it won't turn a complete revolution so I think it may have a valve hung up. Not a big demand for those big 6's so not sure what I'll do with it. After that I want to pull the wheels and check out the drums and brake components to see if they are usable, since there is no new source for the drums and I don't think for the shoes either. I'm not sure that the front axle and the rearend are worth saving, but I know that the frame is not.
I just got a frame for my truck. Its a 1979 snub nose motorhome. Its a GM 1 ton frame and it has a SB Chevy and turbo 400 trans. I got it for a great price. My dad is a service manager for a Chevrolet dealership. So i knew he would force me to use a chevy as much as I hate to. I am the only one in the family with Fords so. If anybody is looking to buy the original frame and drive-train. Just give me a shout. It has the 254 Flathead 6 and i think its a 2 speed rear-end.I would hate for it to go to waste if somebody needs it. well now to go take the cab off and start building.
CruzerDog
03-05-2014 09:06 PM
lunchboxleach
20
08-12-2011 10:03 AM
