Projects Share with other members the details about your project truck or SUV. Old or new, gas or diesel, its all welcome here!
Ambitious plans meets lack of pistons
Old 08-05-2009, 09:29 AM
sybersmith's Avatar
sybersmith
sybersmith is offline
I have a 400M that I am in planning stage of the rebuild. I want these Edelbrock heads http://www.edelbrock.com/automotive_..._sb_clev.shtml
60 cc's closed chamber so a squish area is possible but I can find no piston that will give an acceptable (9 to 1) CR and maintain a squish area.
Flat top pistons, which BTW I also haven't been albe to find will produce around 12 to 1 -- ah if only 110 octane gas were available. It looks like I need a 30cc dish. Actually a D dish if squish area is to be maintained.
Does anyone know? Is 30cc's an impossibly large dish? I've seen 18. Not for this engine but I at least know an 18cc D dish is possible.
With those heads and the right pistons this 400M would be a screamer.
I also plan a fuel injection. The thermactor will have to be changed to blow into the cats instead of the intake manifold as that would interfere with a O2 sensor but I see no problems there -- except possibly legal. Just because it's better, greener, doesn't mean it's legal but I'm hoping if we get inspections here they will be car guys enough to see reason but who knows. A closed loop fuel injection, three way cats and a combustion chamber with a proper squish area would be greener than anything produced by Detroit until at least 1990 and mine is a '77.
If anyone knows anywhere online piston, piston information (I don't even know the stock specs), for the 400M may be found please help.
Old 01-21-2011, 01:09 PM
POPAJON's Avatar
POPAJON
POPAJON is offline
Try Tim Meyers Precision Machining in Minnesota. Tim is a guru with the 351M 400 engines. He can lead you in the right direction. John
Old 01-22-2011, 07:56 PM
fordman75's Avatar
fordman75
fordman75 is offline
Is E85 fuel available where you live? Around here it's cheaper then regular 87 octane it has around 105 octane and runs cooler too. That helps prevent detonation. High compression engines love it!
greentruck72
06-17-2015 09:15 AM
460/5
05-25-2009 10:01 PM
1963f100
05-09-2007 03:50 AM
Blown 331
01-29-2006 04:21 PM
76 F250 4X4
11-29-2003 07:19 PM
Quick Reply: Ambitious plans meets lack of pistons
