Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Western Region > California, Southern Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
California, Southern Chapter Join Chapter, Leader: wpnaes
  #1 (permalink)
Old 01-17-2011, 02:23 PM
Big-old-460's Avatar
Big-old-460 Big-old-460 is offline
Garage is empty, add now
Big-old-460 is starting off with a positive reputation.
Need Help with my 4x4.. Axle angle Problem
I posted this in the Ford f 350 fourm heres the link please help with advice if you can thxs
jayson
http://www.ford-trucks.com/forums/10...xle-angle.html
my axle angle is proventing me from using my 4x4 pics in link thxs..
please post on that link for advice ty
  #2 (permalink)
Old 01-18-2011, 02:26 AM
BigGeo's Avatar
BigGeo BigGeo is offline
BigGeo has a good reputation on FTE.BigGeo has a good reputation on FTE.
Axel Wrap
I did a spring over on my Jeep Wrangler using Dana 44s from an 0lder F150. The angel of my rear drive line was so sever that I had to reweld my spring perches so the driveline pointed up 21.5 degrees so the U-joints would be parallel. I also had to put an anti-axel wrap bar from my rear diff to a crossmember I built, because when you hit the gas the rear axel tends to rise which is called Axel Wrap. With out it I would go through U-joints in a very short time. If I can find the link explaining it better I'll post it. Hopes this help .
George
Here is the link. http://www.4crawler.com/4x4/CheapTri...line-101.shtml
Tags
4x4, angle, axle, axles, problem
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
