For you Dashboard purists, is this better?
That looks very nice, but two things. First, how would you incorporate it into the dash, and two, aluminum has a very different rate of expansion and contraction compared to the material the dash is made of. I would think that even if a seamless repair were made, the differing rates of expansion would tear a line around the panel.
Not gonna be made of aluminium, will be .034 steel, paint to match, planning to
cut speaker area out, use an EPDM "H" channel that will hold the panel and hold the original dash. (just like how your rear window is held in by the gasket) "Wiggle room" will be in the "H" channel.
there is no way to make any repair "seamless" being the nature of brittle vinyl.
Only seamless is a complete recover, and we've seen what happens there.
I was searching the forms, and found a solution to fixing the dash and installing aftermarket gauges
[/QUOTE]
[/QUOTE]
This one over laps all cut edges about 3/8"
This one has a bigger border that the ones I'll make in the future, because you will only cut around the existing speaker holes.
I made the hole in the dash bigger than the actual speaker hole area to try and fit a rubber "U" channel between the patch and the vinyl. So this patch is bigger. didn't work well for "ease of installation.
The border on this one is 5/8".
all others will have a border of @ 1/4"
Clips are not done yet, but the panel will sit snug on top of the vinyl.
(I figured YOU would ask about the "joint")
I suggest to "hot glue" or any other way to bond the edge of the vinyl after cutting. this will help form the vinyl from cracking at the new cut.
