Tech/mod info links
Tech/mod info links
Hey guys. I thought I'd take a little time to gather up some write ups and save them to my laptop for future posting later on. While I was doing this I decided I'd just post them all up here and maybe we can get them stickied. They are in no particular order, just the order I found them in. If anyone has some links saved for something that isn't listed like the CCV mod, D60 swaps, or other write ups, post them up and I will add them to the original post. Thanks guys. Enjoy.
Steve Baz’s page: LOTS OF GOOD INFO HERE!!
Tips - Idea - Hints
PRE vs POST turbo EGT differences w/ pics:
https://www.ford-trucks.com/forums/7...s-for-tim.html
Edge Evolution issues:
https://www.ford-trucks.com/forums/1...rogrammer.html
6637 intake:
https://www.ford-trucks.com/forums/9...iy-intake.html
Midnight Mods: 6637 Mod
3” Downpipe install:
How to: Downpipe Install - PowerStrokeNation
2wd to 4wd conversion:
https://www.ford-trucks.com/forums/9...ng-d-50-a.html
Accelerator Pedal Fix:
https://www.ford-trucks.com/forums/1...-makomark.html
Clear headlight installs:
https://www.ford-trucks.com/forums/98...s-install.html
https://www.ford-trucks.com/forums/1...s-of-pics.html
HID conversion:
https://www.ford-trucks.com/forums/9...s-install.html
HID conversion w/ projectors:
https://www.ford-trucks.com/forums/1...l#post10971175
Fixing common fuel system leak points:
https://www.ford-trucks.com/forums/8...-write-up.html
https://www.ford-trucks.com/forums/9...eak-fixes.html
Rear disc brakes:
https://www.ford-trucks.com/forums/6...-are-here.html
https://www.ford-trucks.com/forums/9...ion-2-0-a.html
HPOP replacement:
https://www.ford-trucks.com/forums/5...-part-1-a.html
TikiWiki : HPOP R & R
Turbo removal:
TikiWiki : Turbo removal 1994.5-1997 PowerStrokes
Turbo Tech:
https://www.ford-trucks.com/forums/1...urbo-tech.html
Glowplug, GPR, winter hard start and white smoke thread:
https://www.ford-trucks.com/forums/4...ke-thread.html
GPR bypass:
Performance Injectors for 7.3L Ford Power Strokes
GPR LED indicator(LED illuminates when GPR is on):
https://www.ford-trucks.com/forums/1...p-led-mod.html
38 gallon rear tank:
Fuel tank vent mod:
https://www.ford-trucks.com/forums/9...-mod-redo.html
10k mod:
TikiWiki : 10 K Mod
https://www.ford-trucks.com/forums/6...on-my-10k.html
Midnight Mods: ICP Resistor Mod – Version 1
SD fuel heater upgrade:
TikiWiki : 94-97 PSD Fuel Heater Upgrade
Injector replacement:
TikiWiki : 94 through 97 Injector R&R
How To: 7.3L Powerstroke Injector Removal and Installation
https://www.ford-trucks.com/forums/9...r-install.html
Injector Cup Replacement:
https://www.ford-trucks.com/forums/9...p-r-and-r.html
FPR shim:
TikiWiki : Shim Your Fuel Pressure Regulator 94-97
Traction bars:
Multifunction switch replacement:
https://www.ford-trucks.com/forums/1...ml#post9952744
Intercooler installs:
1996 Ford F350 4x2 - Intercooler
Ford OBS (1994-1997) powerstroke intercooler instal - Great Lakes 4x4. The largest offroad forum in the Midwest
https://www.ford-trucks.com/forums/9...ll-pt-1-a.html
Tims I/C Page example
Oil Cooler R&R:
https://www.ford-trucks.com/forums/9...-write-up.html
https://www.ford-trucks.com/forums/3...placement.html
Oil Cooler How To...since it's that time of year. - PowerStrokeNation
Transmission Cooler upgrade:
https://www.ford-trucks.com/forums/8...ed-w-pics.html
Transmission Cooler Installation - PowerStrokeNation
Dipstick tube seal replacement: IN TRUCK
https://www.ford-trucks.com/forums/7...-be-fixed.html
Dipstick Tube Seal Replacement - PowerStrokeNation
Gauge install:
Gauge Install
Gauge Installation - 1994-1997 Power Stroke FAQ
Electric fuel:
https://www.ford-trucks.com/forums/9...el-system.html
Electric Fuel Conversion - PowerStrokeNation
Electric fuel system conversion - PowerStrokeNation
ZF5 short throw shift kit install:
Midnight Mods: MidWest Trans Short Throw Shifter Kit Install for ZF5
Chip installation:
http://www.totaldieselperformance.co...stall94-97.pdf
York onboard air:
https://www.ford-trucks.com/forums/8...ally-here.html
Hydroboost conversion:
https://www.ford-trucks.com/forums/9...onversion.html
Converting EBPV to an exhaust brake:
https://www.ford-trucks.com/forums/6...-write-up.html
Converting gas truck to 7.3L PSD:
https://www.ford-trucks.com/forums/9...p-started.html
Converting XL to power windows/locks:
https://www.ford-trucks.com/forums/1...-xlt-swap.html
Adding cruise control:
https://www.ford-trucks.com/forums/1...e-control.html
Common no start issues:
https://www.ford-trucks.com/forums/9...tart-list.html
Clutch rod end bushing repair using heim joint off Ebay:
https://www.ford-trucks.com/forums/8...shing-fix.html
Replacing pedal box bushings:
https://www.ford-trucks.com/forums/9...pic-heavy.html
Sterling 10.25" info:
Ford 10.25 & 10.50-Inch Axle Tips - Four Wheeler Magazine
Ford axle code chart:
Ford Axle Code Chart .: Articles
DIY Auxilary idle controller(AIC):
North Texas Power Stroke Association - DIY AIC Mod
https://www.ford-trucks.com/forums/1020339-diy-aic.html
Upgraded headlight harness:
North Texas Power Stroke Association - APC Super Upgrade Harness and BrightBox Mod
Whiter Whites, Brighter Brights .: Articles
140v IDM:
https://www.ford-trucks.com/forums/8...-140-volt.html
Link to 7point3.com archive--- Powerstroke Mods and Maintenance
Because we don't know how long the archives for 7point3.com and Steve Baz's page(first link here) will be available, I am adding all the links from 7point3.com to this post. It is a good idea to save those two archives to your computer before they are lost forever though. So, links from 7point3.com will start here..
6637 Cross Reference:
https://www.ford-trucks.com/forums/5...reference.html
Common Acronyms:
https://www.ford-trucks.com/forums/1...finitions.html
Mod paths and effects:
https://www.ford-trucks.com/forums/5...confusion.html
Truck buying info(Super Duty based, most can be used on OBS):
https://www.ford-trucks.com/forums/5...questions.html
Oil Filter Study:
http://people.msoe.edu/~yoderw/oilfilterstudy/oilfilterstudy.html
Roadside Help Network:
https://www.ford-trucks.com/forums/5...p-network.html
A/C clutch cycling:
https://www.ford-trucks.com/forums/5...ml#post4464164
Antifreeze in oil:
https://www.ford-trucks.com/forums/5...in-my-oil.html
ATF change(E4OD and 4R100):
Changing ATF Fluid in a E4OD and 4R100 transmission .: Articles
Clutch fork replacement(ZF6, but appears very similar to ZF5):
https://www.ford-trucks.com/forums/4...omplished.html
CPS Change:
How to change the Camshaft Position Sensor on a 7.3 Power Stroke Diesel .: Articles
Dipstick oil leak:
https://www.ford-trucks.com/forums/3...tick-leak.html
https://www.ford-trucks.com/forums/6...with-pics.html
Exhaust backpressure tube cleaning and operation:
https://www.ford-trucks.com/forums/5...-no-power.html
Drain valve fuel leak(SD again, should be the similar for OBS):
https://www.ford-trucks.com/forums/3...king-fuel.html
https://www.ford-trucks.com/forums/5...in-o-rings.htm
http://home.centurytel.net/sabre/drainvalve.htm
https://www.ford-trucks.com/forums/4...rs-are-in.html
IPR Cleaning:
New Page 0
Oil Filter bypass valve replacement(NOTE: 94.5-95 bypass valve is STAKED in place, not c-clipped like in the link!!)
https://www.ford-trucks.com/forums/4...er-housing.htm
Oil Pan rust- POR-15:
https://www.ford-trucks.com/forums/6...5-results.html
EGT readings PRE vs POST turbo:
https://www.ford-trucks.com/forums/4...st3684558.html
6637- under hood temps:
https://www.ford-trucks.com/forums/4...-readings.html
Pyrometer- drilling the manifold:
https://www.ford-trucks.com/forums/5...tallation.html [/FONT]
Tips - Idea - Hints
6637 intake:
HID conversion:
Rear disc brakes:
HPOP replacement:
Turbo removal:
Turbo Tech:
GPR bypass:
Fuel tank vent mod:
10k mod:
TikiWiki : 10 K Mod
FPR shim:
Traction bars:
Oil Cooler R&R:
Gauge install:
Gauge Install
Electric fuel:
Chip installation:
York onboard air:
140v IDM:
Common Acronyms:
Oil Filter Study:
A/C clutch cycling:
Antifreeze in oil:
CPS Change:
Dipstick oil leak:
IPR Cleaning:
New Page 0
Nice trav i think i have a few maybe i can help
Gauge install:
DieselManor - Installation Sheets
Gauge Install
Gauge install:
Gauge Install
Oops i forgot 2
Gauge install:
Injector install:
https://www.ford-trucks.com/forums/9...install-3.html
Gauge install:
Injector install:
I added about 10 more links today. I will search some more tomorrow for stuff I haven't found yet.
Blake, I added those links to the original post. Thank you for posting those for me. reps sent.
Dave, thank you for making this a sticky. Hopefully it will help some people having all these links here instead of having to search for them.
Midnight Mods: Dual Mass Flywheels For Dummies
DMF Breakdown
6637 From RiffRaff
My ICP mod Version 17.8 or whatever the resistance was.
Midnight Mods: Carpet Install
Carpet install
I really wanna do the carpet install again, but its a bit expensive. haha
Learned a few things I coulda done better. I had mine slid a bit further back, I coulda moved it forward about 4 more inches. and I had it slightly crooked.
Its sooo big, its just to hard to tell wtf you have going on.
DMF Breakdown
6637 From RiffRaff
Carpet install
Awesome Thread! You must have read my mind as I was thinking about putting an "index" of threads and articles together just like this. It would have taken me forever to find all of these threads to add, though.
Here's another one:
Keep 'em coming guys. There is a lifetime of knowledge here already! Thanks to all who are so willing to share their knowledge.
Here's another one:
