close ratio NP435 in a Ford.
Old 01-16-2011, 08:31 PM
Cha1se's Avatar
Cha1se
Cha1se is offline
Hello,
I've got a 1984 F100 4X4: https://www.ford-trucks.com/forums/1...ew-member.html
I've put an NP435 in it. It has four forward gears but I really couldn't call it a four speed, as first is basically useless.
I've read that Ch%v and Jeep had NP435s with both the wide and close ratio gears available.
I'm wondering if it's possible to put the gears from a close ratio (from one of the other manufacturer's) into my gearbox.
It wont be an issue that fist isn't so low, as I have low range in the transfer case.
Cheers
Old 01-16-2011, 09:51 PM
85e150's Avatar
85e150
85e150 is offline
Received 1,592 Likes on 1,297 Posts
I see the Dodge has a taller first and a little closer overall. No idea if it will interchange into the Ford case with the Ford input shaft etc.
The New Process 435 Transmission - Novak Conversions
A T19 from a BB or Diesel Ford would have closer ratios. Not sure if you can find one of those.
That site also has info on them if you go back to the trans info bar.
Good luck with it.
T_Cooksey88
03-06-2016 11:46 AM
Ken Blythen
01-09-2013 12:14 PM
FarmerFrank
1978 - 1996 Big Bronco
06-21-2010 10:27 PM
bigoldblue
04-06-2007 05:58 PM
rustyolred27
03-24-2003 11:45 AM
Quick Reply: close ratio NP435 in a Ford.
