6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
loss power 6.4
Old 01-16-2011, 05:56 PM
mspurr's Avatar
mspurr
mspurr is offline
loss power 6.4
I have a 2008 F-350 with loss power, if I'm driving at about a 100 km and floor the truck to pass a car i have no power about a 1/4 of boost, then if you let off and ease in to the peddle the boost comes up but slowly. if you pull over and shut the truck off and start it back up the power is back and works find till u drive at a 100 or slower for 10 or 15 min. some times if you hold the peddle to the floor till it govern out the power will come back. i have had it in to ford a few time and they can't find anything wrong with it.
Old 01-16-2011, 07:42 PM
senix's Avatar
senix
senix is online now
Received 1,400 Likes on 997 Posts
This could be a hard one to pin down. How many miles and what type of driving do you do?
This could be anything from clogged fuel filters or a VCV valve. Maybe an EGR related issue.
I take it no check eng light or a wrench? Any white smoke or black smoke?
Old 01-16-2011, 07:59 PM
Larry NCKS's Avatar
Larry NCKS
Larry NCKS is offline
Your engine is derating or going to limp mode for some reason. It has a fault in the system somewhere that is telling the PCM not to let it power up.
Old 01-16-2011, 08:54 PM
mspurr's Avatar
mspurr
mspurr is offline
I do lots of long drives and a fare bit of idling, two weeks a go i had it in to ford to have the egr valve cleaned but they checked every thing over and told me it was a wast of money to clean the egr everything was running fine,
What is the VCV valve do?
there is no CEL or smoke it has gotten worse now that i am working in -30 C temp i do have a winter front on and do us conditioner for the fuel,
I have notice the odometer display flicker a few times a day.
when it go in to regen it only display it on the screen for a few sec, then it is gone
there are no mods doen and i am 158,000 km on it
I did buy the truck used
Old 01-17-2011, 05:37 AM
senix's Avatar
senix
senix is online now
VCV is Volume control valve. Regulates the fuel pressure sent to the rails. My thoughts are to look at your fuel pressure.
Old 01-17-2011, 07:47 AM
Larry NCKS's Avatar
Larry NCKS
Fuel pressure/flow should set a code, should it not? Of course there's no accounting for computers sometimes, nor is there for some dealerships.
Old 01-17-2011, 08:51 AM
senix's Avatar
senix
senix is online now
yes it should be I'd check it with a guage.
Old 04-05-2015, 05:11 PM
JB25081's Avatar
JB25081
JB25081 is offline
Sounds similar to my issue, what did you find out the problem was?
Old 04-06-2015, 12:43 PM
SANDDEMON08's Avatar
SANDDEMON08
SANDDEMON08 is offline
Sounds like you still have the DPF and all emissions installed on the truck. Assuming the truck is stock and has no tuner, What does the tail pipe look like? Clean or sooty black?
Old 04-07-2015, 11:17 PM
parkland's Avatar
parkland
parkland is offline
Sound advice, just a little late!
lol
Old 04-09-2015, 01:05 AM
SANDDEMON08
lol
Lmao! i didn't even look at the date......
Old 02-03-2022, 11:43 AM
Wiley95's Avatar
Wiley95
Wiley95 is offline
lol
I know it says 2015 but did you ever find out the problem mines doing it now and I'm stumped
Old 02-03-2022, 11:47 AM
Wiley95's Avatar
Wiley95
Wiley95 is offline
I know this is a old trend but did you ever find out what was wrong mine has started doing this and I am stumped
Old 02-03-2022, 07:31 PM
DieselDenny's Avatar
DieselDenny
DieselDenny is offline
Wiley, Best advice is start a new thread!
This one is dead.
Denny
Old 02-04-2022, 08:29 AM
Fefanatic's Avatar
Fefanatic
Fefanatic is offline
Start a new thread about this and then I will ask you if it is smoking when you floor it, have you changed your fuel filters, have you checked all cac pipes, have you scanned for any codes.
dan9812
1999 to 2016 Super Duty
09-24-2016 07:18 AM
Truckinon59
New Member Introductions
09-21-2015 01:32 PM
radmacks
04-10-2015 10:18 PM
patrick huston
12-24-2014 01:14 AM
miller502
15
01-23-2007 06:57 PM
Quick Reply: loss power 6.4
