Need help installing OEM foglights.... - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 01-16-2011, 06:48 PM
ETKMS's Avatar
ETKMS ETKMS is offline
ETKMS is starting off with a positive reputation.
Last week I ordered some OEM fog lights for my 2008 F450 XLT from partsguyed. I recently heard he had health issues, I wish him all the best, but I do not want to bother emailing him at this time.
He did mention at first, the XLT is all wired for them? Although they wont be here till Wednesday, I looked under the truck today, and I cannot seem to find out where the wirning is that i will need to connect them to. Has anyone does this before? if so can you let me know where I wire it too?
Thanks
Old 09-03-2012, 09:31 PM
markmc60 markmc60 is offline
markmc60 is starting off with a positive reputation.
I have the same question on my 2005 F350, ghot thew lights, the auto lamp switch in my xlt super, but no wiring harness present where the fogs go. what did you find out?
Old 09-03-2012, 11:32 PM
Yahiko's Avatar
Yahiko Yahiko is offline
Yahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputation
Look Driver side near the front frame rail and inner fender well.
You may need to install the relay to get them working. You should see
2 wires in a jacket with a plug on the end. Before you plug in be sure to
use some contact cleaner on it to remove and dirt and corrosion. Then top
it off with some dielectric grease to keep is dry and clean.
Sean
Old 09-04-2012, 03:36 AM
ETKMS's Avatar
Quote:
Mine was easy, i found the wiring harness and it was plug and play! But I am not sure if it is the same on an 05, so I cannot comment since mine was on an 08.
Old 09-04-2012, 06:22 AM
SlickYamaha's Avatar
SlickYamaha SlickYamaha is offline
SlickYamaha is gaining momentum as a positive member of FTE.SlickYamaha is gaining momentum as a positive member of FTE.
I did mine on my 11, alot may have changed, but the plug for mine was in the center of the bumper, with a cap on it, tucked up behind. If your laying under the truck, its almost behind where you would think the license plate would be.
I also had to replace the switch for my lights on my dash, instead of twisting the switch for headlights, you also pull it out for fogs.
Old 09-05-2012, 11:03 AM
tmaglin's Avatar
tmaglin tmaglin is offline
tmaglin is starting off with a positive reputation.
Quote:
I have an 08 XL. I was told the connecting harness is to the left of the horn, on the drivers side. It has a dummy plug in the connector. So, far, I have replaced the head light switch with the one that pulls out for fog; however, when I remove the dummy plug and check for current with a test light, there is no current at the harness. What am I missing?
Old 09-05-2012, 11:22 AM
DarrellinCeres DarrellinCeres is offline
DarrellinCeres is gaining momentum as a positive member of FTE.
Some use a relay between the switch and the light. If it didn't come with fog lights perhaps the relay and fuse didn't get installed.
Old 09-05-2012, 02:31 PM
Yahiko's Avatar
Most likely it is what
DarrellinCeres said.
Relay missing
I find it helpful to have a good wiring diagram
for the year and model being worked on.
Sean
Old 09-06-2012, 07:45 AM
Yep, I have to get the harness that runs between Fogs(L&R) and connects to the truck plug. guess I will go to the junk yard. thanks folks for the help.
Old 09-06-2012, 04:30 PM
ETKMS's Avatar
Quote:
Are you checking this with the key in the on position or the truck running? unlike the headlights which can turn on when the truck is off with no key in, the fog lights need the the truck to be in running or have the key in the on position in order for them to light up.
Old 09-10-2012, 04:34 PM
tmaglin's Avatar
Sean
Can you tell me where the relay installs. my truck has the wiring, but no relay.
Old 09-11-2012, 10:42 AM
tmaglin's Avatar
I have checked with the key in the on position and also checked with the engine running. still no current, and can't hear a relay. According to the fuse diagram, the fog lamp fuse is number 21, a 15 amp fuse which I did find; however, I have no idea as to where the relay is located. Any ideas?
Old 09-11-2012, 03:58 PM
Yahiko's Avatar
I don't have a diagram for you year. Do you
have access to the owners manual? It should
show you where that relay is. On the 06 it's
in the CJB in the cab location 2.43.
Sean
Old 09-11-2012, 05:24 PM
TexasRebel's Avatar
TexasRebel TexasRebel is offline
TexasRebel has a great reputation on FTE.TexasRebel has a great reputation on FTE.TexasRebel has a great reputation on FTE.TexasRebel has a great reputation on FTE.TexasRebel has a great reputation on FTE.
if you are checking current without bulbs installed you probably blew the fuse on your multimeter or the pickup itself as you shorted the hot side to ground.
you should check voltage if you want to check anything. My '08 XL was plug & play.
Mirror Question....Please bare with me... Bruinzfan 2007 - 2014 Expedition & Navigator 1 02-11-2015 09:44 AM
COLOR CODE or Wiring Diagram for F-350 SD Delawhere? 6.7L Power Stroke Diesel 8 12-05-2013 07:48 PM
Adding OEM Backup Camera to 2012 F350 Dually MrAgent007 6.7L Power Stroke Diesel 8 02-08-2012 12:15 PM
'95 explorer oem cassette into 92 f150 oem h-m Audio & Video Systems, Navigation, Satellite Radio & Mobile Electronics 0 09-21-2009 01:57 PM
Searching for OEM Ranger CD-Radio PhiladelphiaCub Ranger & B-Series 4 07-07-2003 09:58 AM
Tags
1997, 99, duty, f250, factory, fog, foglights, ford, installing, lights, oem, super, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
