Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks Discuss the Early Eighties Bullnose Ford TruckSPONSORED BY:
  #1 (permalink)
Old 01-16-2011, 03:32 PM
mcwbyu82 mcwbyu82 is offline
Garage is empty, add now
mcwbyu82 is starting off with a positive reputation.
Panel/Bezel Removal For New Radio
Hey everyone. Planning on celebrating MLK day by installing my new radio deck and speakers. The radio wiring/install I am good on.
Just looking for instructions/tips for removing the door panels and bezel to get at the radio and speakers. I am sure it isnt too complicated but I really dont want to snap or bend anything I dont need to.
1982 F150 reg Cab XLT
Also my XLT bezel is in perfect shape with factory amfm cassette player.
Want to put my bezel out there for someone looking to to stay factory before I cut it up for the DIN radio. Obviously I would need a matching bezel in good/great shape that is already cut for DIN in return.
  #2 (permalink)
Old 01-16-2011, 03:43 PM
Franklin2's Avatar
Franklin2 Franklin2 is offline
1989 Ford F-250
Franklin2 has much to be proud ofFranklin2 has much to be proud ofFranklin2 has much to be proud ofFranklin2 has much to be proud ofFranklin2 has much to be proud ofFranklin2 has much to be proud ofFranklin2 has much to be proud ofFranklin2 has much to be proud ofFranklin2 has much to be proud ofFranklin2 has much to be proud of
There is a screw down in the pocket where you put your hand to close the door. Take this screw out, take a large flat scraper and pry the out edge loose, and then lift up and wiggle to get the door panel off. Expect to break some of the clips, it always happens.
__________________
Dave F
1989 F250 XLT Diesel
  #3 (permalink)
Old 01-16-2011, 03:45 PM
bashby's Avatar
bashby bashby is offline
1992 Ford F-250
bashby has a very good reputation on FTE.bashby has a very good reputation on FTE.bashby has a very good reputation on FTE.bashby has a very good reputation on FTE.
take the window crank off too
__________________
92 F250 4x4 7.3idi zf5 3.55's Meyer plow
86 F350 2wd C&C Dump 351w C6 4.10s Meyer plow
The rest of my signature changed as to not offend some liberal crybaby.
  #4 (permalink)
Quote:
So am I "prying" all along the entire edge of panel? And when I break these clips can i find them at the auto parts store?
  #5 (permalink)
Old 01-16-2011, 03:51 PM
bashby's Avatar
1992 Ford F-250
Quote:
Yes. The clips are along the sides and bottom of the door panel.Start at the bottom. once you can get your hand in there just pull on it. When you get the panel loose from the clips, you lift straight up on it to clear the lip on the top of the panel. I think napa carries the clips, not sure about autozone. If you're missing a couple it wont cause any problems
__________________
  #6 (permalink)
Old 01-16-2011, 03:58 PM
Thanks. Any tricks for the bezel?
  #7 (permalink)
Old 01-16-2011, 04:04 PM
bashby's Avatar
1992 Ford F-250
IIRC 2 philips screws up top then just swing it down and it comes off
__________________
  #8 (permalink)
Old 01-16-2011, 04:05 PM
Rogue_Wulff's Avatar
Rogue_Wulff Rogue_Wulff is offline
Rogue_Wulff is a name known to allRogue_Wulff is a name known to allRogue_Wulff is a name known to allRogue_Wulff is a name known to allRogue_Wulff is a name known to allRogue_Wulff is a name known to all
There is a tool made for popping those plastic clips out with minimal damage. It's named, appropriately enough, door panel removal tool. It has a bend in it, and the end has a notch for those clips to fit into. The idea is to get the notched part between the door and the head of the clips, and pry out.
As for the radio bezel removal, theres a couple screws up top, just below the dash pad, and I think a couple more down towards the bottom. It's really easy to get off.
When I put a DIN type radio in my truck, I went a salvage yard and bought a dash bezel from an 85/86. Those had DIN style radios factory.....
__________________
1980 F-150 300 I6, C6 & 9" rearend. The workhorse. 300K+
1974 F100 Ranger XLT 390, C6 3.25 axle. Dad bought it new, drove it over 500K. Now that he can no longer drive it came to me. Value: Priceless.
1983 Mazda RX7 1.1L Rotary. The show/autocross/toy. 231K
1995 Mazda B2300 (undercover Ford)
  #9 (permalink)
Old 01-16-2011, 04:08 PM
Will the 85/86 bezels have the same wood grain?
  #10 (permalink)
Old 01-16-2011, 04:19 PM
Dunno if the same style woodgrain was offered in 85/86. The one I got had a different style woodgrain.
__________________
  #11 (permalink)
Old 01-16-2011, 05:09 PM
Anafiel's Avatar
Anafiel Anafiel is offline
1985 Ford F-150
Anafiel has a very good reputation on FTE.Anafiel has a very good reputation on FTE.Anafiel has a very good reputation on FTE.Anafiel has a very good reputation on FTE.
Speaking of, I have this that I got out of a jy donor when I pulled the instrument cluster for it's factory tach.
It's cut for DIN, and the woodgrain has some issues, and I don't need it. Anyone needs it, just pay the shipping.
PM me and it's yours.
Cut bezel from 84 XLT
(I hope this wasn't against any kind of forum rule, I just didn't want to throw it away before I offered it out for free)
__________________
1985 F150 XL 2x4 351W
92 Eddie Bauer Bronco 4x4 351W EFI
The system didn't fail...the jury failed the system!
Tags
1985, 1989, 1990, 1995, b2300, bezel, dash, f150, ford, mazda, oriningal, radio, ranger, removal, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
