Pictures of processors - Ford Truck Enthusiasts Forums
Old 01-16-2011, 03:08 PM
fabmandelux's Avatar
fabmandelux fabmandelux is offline
fabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputation
Arrow Pictures of processors
I've had quite a few people ask for pics of processors so decided to add a sticky for it. If you have pics of your system post them here for others to look at!
I will sticky this thread but not lock it, so everybody can have access.
Let's see if we can help others to get started!
Old 01-24-2011, 09:01 PM
binuya's Avatar
binuya binuya is online now
binuya has a great reputation on FTE.binuya has a great reputation on FTE.binuya has a great reputation on FTE.binuya has a great reputation on FTE.binuya has a great reputation on FTE.binuya has a great reputation on FTE.
OK, I'll go first. Compared to some of the regulars here, my set up is probably the most primitive, but it works well for me. I water wash. My 55 gallon drum processor is also where I spray dry my bio after washing.
Here's the setup with heated standpipe wash tank to the left, processor in the middle, and pneumatic drill powered keg methoxide mixer to the right. Both wash tank and processor have 220v heating elements wired 110V thermostat controlled.
Here's the simple processor plumbing. This is fed into a cheap HF blue pump which has, surprisingly, held up well processing and drying just over 1500 gallons of bio. I am currently constructing a new processor which will have a Pedrollo pump. Better quality and much safer.
Old 02-06-2011, 11:10 PM
Rushmore X's Avatar
Rushmore X Rushmore X is offline
Rushmore X has much to be proud ofRushmore X has much to be proud ofRushmore X has much to be proud ofRushmore X has much to be proud ofRushmore X has much to be proud ofRushmore X has much to be proud ofRushmore X has much to be proud ofRushmore X has much to be proud ofRushmore X has much to be proud of
Ok, now I'm going to have to update my pics.... Hopefully sometime this week. Gives me something else to do...
Old 03-08-2011, 12:46 AM
muns53's Avatar
muns53 muns53 is offline
muns53 is starting off with a positive reputation.
I threw some pics of my conversion and my grease shack in my picture album. Nothing fancy, I'm filtering with a bowl-type centrifuge & burning WVO in a 2-tank system (modified Vegistroke V3) on my Excursion, not making bio.
Old 04-04-2011, 10:33 PM
flainn's Avatar
flainn flainn is offline
flainn has a very good reputation on FTE.flainn has a very good reputation on FTE.flainn has a very good reputation on FTE.
Here's my processor, a pretty much bone stock Appleseed design made from a 40-gallon Home Depot water heater and currently installed on my 5'x8' trailer:
And here's my three WVO storage barrels and my wash tank:
Not pictured is my "super sucker", made out of a 50-gallon propane tank, which is also mounted on my trailer.
The processor and wash tank plans and parts kits were purchased from <a href="http://www.utahbiodieselsupply.com/">Utah Biodiesel Supply</a> (great folks!) and the Super Sucker plans were purchased from <a href="http://www.murphysmachines.com/">Murphy's Machines</a>.
Old 04-30-2011, 10:32 PM
frdf250's Avatar
frdf250 frdf250 is offline
frdf250 has a very good reputation on FTE.frdf250 has a very good reputation on FTE.frdf250 has a very good reputation on FTE.frdf250 has a very good reputation on FTE.
Pictures of Setup
Heres some picture of my setup. Finally got the swing of things, thanks to you guys.
Old 01-17-2012, 04:38 PM
Rushmore X's Avatar
Finally got around to it.
Old 02-19-2012, 11:40 AM
ATV PRO #11's Avatar
ATV PRO #11 ATV PRO #11 is offline
ATV PRO #11 is a splendid one to beholdATV PRO #11 is a splendid one to beholdATV PRO #11 is a splendid one to beholdATV PRO #11 is a splendid one to beholdATV PRO #11 is a splendid one to beholdATV PRO #11 is a splendid one to beholdATV PRO #11 is a splendid one to beholdATV PRO #11 is a splendid one to behold
I have tons of pics of the plant throughout the build. Can't seem to figure out how to post on here. Don't think i'll get in trouble as the process was propritory not the set up/fabrication of the plant
Old 03-02-2012, 01:00 AM
I'd like to see some pics of your set up
Old 03-02-2012, 01:03 AM
stemo76's Avatar
stemo76 stemo76 is offline
stemo76 is starting off with a positive reputation.
Quote:
The easiest way is to post them to a place like photobucket and then you can add the link in the post or use the picture icon and add the url to the specific picture. Photobucket makes getting the links very easy.
Old 03-02-2012, 01:04 AM
Old 03-02-2012, 01:05 AM
Quote:
Thanks!! I finally figured it out with some help. Appreciate it tho
Old 03-09-2015, 10:01 PM
TheCurtster's Avatar
TheCurtster TheCurtster is offline
TheCurtster has a good reputation on FTE.TheCurtster has a good reputation on FTE.TheCurtster has a good reputation on FTE.
Here's my setup
This was during the processing of my first 20 gallon batch. Bought the processor, half drum of methanol, NaOH, filters, pumps barrels, etc. from a CL ad for $700. First batch was a success! Running about 30-40% ratio now. Getting up my nerve for a full 40 gallon batch next week.
Curt
microprocessor in dash for ac? munireusa Excursion - King of SUVs 8 11-11-2016 08:43 AM
My Bio processor N2ZPY Bio-diesel, Propane & Alternative Diesel Engine Fuels 18 11-15-2012 11:41 PM
Use of copper in a processor. binuya Bio-diesel, Propane & Alternative Diesel Engine Fuels 4 09-16-2009 09:56 PM
Appleseed Processor FlyCanadianGuy Alternative Fuels, Hybrids & Mileage 2 12-11-2008 11:41 PM
DIY biodiesel processor plans? moebdick Bio-diesel, Propane & Alternative Diesel Engine Fuels 4 10-24-2004 05:52 AM
Tags
2003, 2011, biodiesel, diesel, engine, f250, ford, keg, methoxide, pictures, processor, processors, tank
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
