Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 01-16-2011, 02:08 PM
fabmandelux's Avatar
fabmandelux fabmandelux is online now
1935 Ford pickup
fabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputation
Arrow Pictures of processors
I've had quite a few people ask for pics of processors so decided to add a sticky for it. If you have pics of your system post them here for others to look at!
I will sticky this thread but not lock it, so everybody can have access.
Let's see if we can help others to get started!
__________________
Oregon Chapter Leader My friends call me Don.
"I always keep a supply of stimulants handy in case I see a snake, which I also keep handy" WC Fields
  #2 (permalink)
Old 01-24-2011, 08:01 PM
binuya's Avatar
binuya binuya is offline
Garage is empty, add now
binuya has a very good reputation on FTE.binuya has a very good reputation on FTE.binuya has a very good reputation on FTE.binuya has a very good reputation on FTE.
OK, I'll go first. Compared to some of the regulars here, my set up is probably the most primitive, but it works well for me. I water wash. My 55 gallon drum processor is also where I spray dry my bio after washing.
Here's the setup with heated standpipe wash tank to the left, processor in the middle, and pneumatic drill powered keg methoxide mixer to the right. Both wash tank and processor have 220v heating elements wired 110V thermostat controlled.
Click the image to open in full size.
Here's the simple processor plumbing. This is fed into a cheap HF blue pump which has, surprisingly, held up well processing and drying just over 1500 gallons of bio. I am currently constructing a new processor which will have a Pedrollo pump. Better quality and much safer.
__________________
2001 F250 7.3 CC SB 4x4 Lariat
S&B Intake, MBRP 4" Turbo Back, HPX, AIH Delete, Hutch and Harpoon,
Isspro EV2's, Bilsteins, Warn Premium Hubs, Firestone Bags with Airlift onboard, Fumoto,
Homebrew American Biodiesel (B100 whenever I can)
1995 Mercedes Benz E300D, 2004 Mercedes ML350
  #3 (permalink)
Old 02-06-2011, 10:10 PM
Rushmore X's Avatar
Rushmore X Rushmore X is offline
2003 Ford Excursion
Rushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to behold
Ok, now I'm going to have to update my pics.... Hopefully sometime this week. Gives me something else to do...
__________________
Trent - 2003 Excursion (Eddie Bauer) 4X4, 7.3, Hellvig antisway bar, 6637 intake mod, 4" MBRP w/ 5" tip, DP tuner, IH up-pipes, redhead steering box, 6.0 trans cooler, ISSPRO & Aeroforce gauges in A-pillar, Wicked Wheel, "Bullet Proof" Transmission rebuilt by Rapid Diesel, extra leaf spring added all around, more to follow! Gone BIO!!!
2002 TDI New Beetle - also likes Bio.
  #4 (permalink)
Old 03-07-2011, 11:46 PM
muns53's Avatar
muns53 muns53 is offline
muns53 is starting off with a positive reputation.
I threw some pics of my conversion and my grease shack in my picture album. Nothing fancy, I'm filtering with a bowl-type centrifuge & burning WVO in a 2-tank system (modified Vegistroke V3) on my Excursion, not making bio.
  #5 (permalink)
Old 04-04-2011, 09:33 PM
flainn's Avatar
flainn flainn is offline
1994 Ford F-250
flainn is gaining momentum as a positive member of FTE.flainn is gaining momentum as a positive member of FTE.
Here's my processor, a pretty much bone stock Appleseed design made from a 40-gallon Home Depot water heater and currently installed on my 5'x8' trailer:
And here's my three WVO storage barrels and my wash tank:
Not pictured is my "super sucker", made out of a 50-gallon propane tank, which is also mounted on my trailer.
The processor and wash tank plans and parts kits were purchased from Utah Biodiesel Supply (great folks!) and the Super Sucker plans were purchased from Murphy's Machines.
  #6 (permalink)
Old 04-30-2011, 09:32 PM
Philip Berardi's Avatar
Philip Berardi Philip Berardi is offline
2000 Ford F-250
Philip Berardi has a very good reputation on FTE.Philip Berardi has a very good reputation on FTE.Philip Berardi has a very good reputation on FTE.Philip Berardi has a very good reputation on FTE.
Pictures of Setup
Heres some picture of my setup. Finally got the swing of things, thanks to you guys.
__________________
Philip Berardi - 2012 F250 Lariat CC SB FX4 - Weather Tech Floor Mats / AVS Vent-Visor / H&S (on the closet shelf until 35k )/DRL/Switch Back Mod
  #7 (permalink)
Old 01-17-2012, 03:38 PM
Rushmore X's Avatar
2003 Ford Excursion
Finally got around to it.
__________________
  #8 (permalink)
Old 02-19-2012, 10:40 AM
ATV PRO #11's Avatar
ATV PRO #11 ATV PRO #11 is offline
ATV PRO #11 is gaining momentum as a positive member of FTE.
ATV.PRO.RACER.11
I have tons of pics of the plant throughout the build. Can't seem to figure out how to post on here. Don't think i'll get in trouble as the process was propritory not the set up/fabrication of the plant
  #9 (permalink)
Old 03-02-2012, 12:00 AM
ATV.PRO.RACER.11
I'd like to see some pics of your set up
  #10 (permalink)
Old 03-02-2012, 12:03 AM
stemo76's Avatar
stemo76 stemo76 is offline
1999 Ford F-350
stemo76 is starting off with a positive reputation.
https://www.facebook.com/profile.php?id=100000160923877 whatusaytome http://www.linkedin.com/in/stephenemorrison cornholio0076
Quote:
The easiest way is to post them to a place like photobucket and then you can add the link in the post or use the picture icon and add the url to the specific picture. Photobucket makes getting the links very easy.
  #11 (permalink)
Old 03-02-2012, 12:04 AM
ATV.PRO.RACER.11
  #12 (permalink)
Old 03-02-2012, 12:05 AM
ATV.PRO.RACER.11
Quote:
Thanks!! I finally figured it out with some help. Appreciate it tho
Tags
2003, 2011, biodiesel, diesel, engine, f250, ford, keg, methoxide, pictures, processor, processors, tank
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
