You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Can anyone give me an update on Ford's stance on tuners on the 6.2? I do know 6.0 diesel issues caused Ford to blame almost everything on tuners if they even thought it had ever had one. Has that changed, or are we still under the play and get caught you pay? Kent
That's a question I would ask your dealer's service department. For the most part, historically, gassers are not subjected to as much scrutiny, especially those engines that aren't supercharged or turbocharged (like the EcoBoost).
However, if you had a major engine failure and a tune was installed, I'm sure that Ford would have a problem with it.
__________________
- art k. - Moderator for the Superduty, V10, 6.2L and FE forums
'13 Taurus SHO 3.5L Ecoboost w/Perf Pkg
'01 F250SD SC SB XLT V10 4x4 Volant CAI Hedman headers 5-star custom tunes on SCT X3
'97 Cougar XR7 30th Anniv Edition 4.6L
'74 F250 Highboy FE390 deceased! I've been wrong before, I'll be wrong again. Just wait and see. ®
Rumor is that Ford can tell you've run a tune, even if you revert back to stock. I'm not sure anyone has verified this 100% but if I were to tune, it will be after the warranty is up.
__________________
2011 F250 6.2L XLT Crew Cab 4x4, 3.73.
Golden Bronze Clearcoat Metallic
2012 Coachmen Freedom Express 292BHDS
ARE Z Series Cap & BedRug Audio upgrade
Of course they can tell. You're reflashing the programming. That will show a date/time stamp change each time it's done at a minimum. The question is...do they look for this as a matter of course? I'd bet not, but I'll also bet they look carefully if the truck is in for something major with the engine/powertrain.
I'm not so sure about the time stamp, but there is a counter for the number of reflashes done, or so I've heard.
__________________
I just talked to a friend of mine who is a Ford tech a few minutes ago. He said if there is a big issue, and the dealer wants to get a ford engineer involved, they can bring out a different computer and find anything and everything that has been done to the pcm. BUT, if you have a tuner, and set it back to the stock tune before going in, the tech has ZERO way to know if you have had a tuner hooked up before. SO, it is a gamble, but like he said, flash it back to stock and they will have no reason to think you have had it tuned.
__________________
2011 F250 R/C Long Bed 4x4 6.2L Tuxedo-Black, Husky Mud Flaps, Dual Mode Reverse/Auxiliary Flood Lights, Air Horn
Custom Side Exit True Dual Exhaust(Think Lightning)
Tuned by *****5 Star Tuning***** Coil On Plug Info Re: Modular Ford Engines
Try to find an aftermarket friendly dealership. Obviously, reverting back to a stock tune is ALWAYS a good idea, BUT..... some dealers will grab at straws to void your warranty (I've heard of K&N filters being justifiable cause to terminate the warranty).
Truck Paradise works directly with a local dealership that tends to look the other way when it comes to tame modifications. Cold air intakes, Leveling kits or small lifts, full exhaust AS LONG AS IT KEEPS THE DPF, and tuners that do not alter or modify the wiring (Edge Juice and Attitude would definately not be overlooked, but a reflash would). Obviously, if your 6.0 has blown a headgasket, due to too much boost................... and they see signs of a tune, that would probably not be covered.
I know that Ford makes these trucks very easy to modify, and there has to be a bit of wiggle room that they give dealers to keep some vehicles under warranty.
Shame...you're like 5 hours from me on the other side of the state.
__________________
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
