5.4l 9-10 mpg on highway
I have a 2008 crew cab reg box with 5.4l with some mods like k&n cai, magnaflow exhaust, throtle body spacer and bully dog gt. I thought that all these put together would help fuel mileage but it never changed a thing. Also does anyone know if this year of motor has the spark plugs siezed in the block with that 2 piece spark plug.
I have an '09 truck, and there are times when 10mpg is as good as it gets. If I'm going against a strong headwind, my fuel efficiency stinks. But when the wind isn't blowing 25mph against my grill, my big truck will pull some respectable numbers for what it is.
Mods don't typically help has engines gain much fuel efficiency. I'm tuned with a SCT X3 and have not noticed any boost in MPGs.
How's your truck set up?
Tire size?
Axle ratio?
Unfortunately, 3.73 and the 5.4L don't get the mileage boost many think over the 4.10 and 5.4L combo. Especially with larger than stock tires.
Tire size?
Axle ratio?
I had the troubled plugs in the truck when I changed them (93k miles on them); Denlors Tools has the extractor tool for about $90 shipped to your house (if one or more breaks, get the tool).
Some aftermarket parts help with mpg - as well as performance. You won't get both.
a double length cab and an 8' bed is the longest (and heaviest) combination you can get in a F250.
Combine that with the smallest numerical gear ratio and the smallest engine available and you've got a setup that has to work pretty hard to get moving and keep speed up a hill.
One thing to do is to make sure you're running the recommended 65-psi front and 70-psi rear tire inflation pressures... it will lower rolling resistance.
I have the 2008 cc lb 2wd 373's and have a high camper top with the tool bins and also carry a spare 98 gal. fuel tank. The truck weighs 9500 lbs. with the basic tool and parts load and full fuel tanks and in the city I get 10.4 mpg's, or 10.8 mpgs when the air is cold in the winter time. That is with the stock 275x65x17 inch tires at 80 psi. I just swapped to 18 inch wheels with the continentals with no difference. I don't do too much highway driving but when I do I probably get maybe 2 more mpg's. I would bring your truck into the dealer and have them re-flash the computer you never know maybe it will help. I have a heavy foot sometimes, but I really don't think it makes too much difference either way. Did you try hand calculating the mileage or do you go by the lie-ometer?
To get an idea of what the error is, use this link: http://www.miata.net/garage/tirecalc.html For the "stock" tire size, use the size on the door post sticker; use the current tire size as the "new" tire.
I have a 08 CC short bed 2wd and in the last month with the cold start warmups the lie o meter says around 11 mpg. Hand calculated its 10.5 to 10.7. Just did a mostly highway/interstate drive of 200 miles plus and LOM said 14.7 hand calc. was 14.5. The lie o meter is constantly .5 to .2 higher than actual numbers. Also, my truck had the two piece plug, broke one removing. Someone here had a build date that after that date 08's had the new style plug. Don't remember the date, but at the time I checked and mine was manufactured about a month to soon. Good luck.
