First time Diesel Owner with F450 and some quetions
#61
Also, I wanted to mention, ever since I drained the water from the separator, i keep getting a "drain water separator light on" i drained it again, got nothing but fuel, light kept coming on. I brought the truck to the dealer, and do you guys remember the loud whistle i had? well, they said it may be an exhaust leak and may require the cab to come off! I will know tomorrow what they say for sure.
#62
#63
They did not even get to the water separator issue, I told them right off the bat bringing it in, that since there was so much slime and gunk, just replace the sensor and clean out the separator good....
They are also going to reflah the ECU to the new version.
#64
Ok, the dealer called me earlier today. I am not sure what he meant yesterday as they were taking the turbo off and inspecting it. It turns out he tried inspecting something, and him and the shop foreman determined the turbo assembly needs to be replaced? My service advisor didn't know much, I said what do you mean assembly? and he said they are going to replace both turbo's and need to take the cab off!!!!!!!!!!!!!!
I am very upset the cab needs to come off! I just installed so many things, even my backup camera which is wired like crazy from A pillar, to the front fuse box, then to the rear of the truck!!!!
#66
I have a warranty, I am not paying. But you do not need to take the cab off to replace both turbos? and what is the turbo assembly they mentioned?
#67
Ok, I went to the dealer today, drove to the back and saw my truck with the cab off! wow! what a sight! Anyway, I figured I would just talk to the tech directly to avoid any confusion. he is replacing both turbos, and he also said most of the whistle noise i heard was an exhaust leake he found, from the up pipe, and he showed me a lot of black smoke residue on the down pipe, and also on the cab heat sheilds. I think he also pointed out some gasket on top of the engine that the turbo connects to he was replacing too. He has all this work to do, yet somehow, he said if all the parts are in by the morning he can have it done by the end of the day!? I doubt that!
#70
I gues when a person installs extra electronics you want to put in quick disconnects between the cab and the chassis if that is where they run. Save a lot of time IF this happens and probably like a computer....Not IF but WHEN it happens.
Has been a good thread. I also have the 08 4x4 6.4 and 4.88 rear. Love the unit and get about 12 mpg driving 65 and at 70 11.8. That is empty. Have not pulled with it yet. Also took the DFP/CAT off yesterday. Really sounds different. Will chip it this week. Have a 14,000 # 5er that I will be pulling with it.
Bought the SCT Livewire PCM Flash tool Hope to see some mileage increase.
#71
He can get this done quickly with the cab off. I think Cheezit said at one time it was only a couple hour job. So 4 hours total for the cab and about an 1.5 hours for the turbo and exhaust and you are done.
#72
Turbo Down pipe gasket needed to be replaced on my 450. The dealer said it was a 1.5 hour job and would be accomplished with the cab on as per the ford maintenance inst.
Since the cab did not need to come off I bought the parts and replaced the gasket took me 2.0 hours to do. PS not convered under warrentee.
#73
The exhaust leak at the pipes has happened to a few people. Cab off is the procedure. Don't think the turbo's were leaking myself. But I am not there either. Pulling them and replacing the gasket certainly wont hurt anything.
#74
#75
I'd talk with the dealer about that, it's not your fault that the cab had to come off. Maybe they can fix everything for you when they put the cab back on...
