351 winsor cranks but wont start - Ford Truck Enthusiasts Forums
Old 01-16-2011, 03:21 AM
ethans91bronco ethans91bronco is offline
ethans91bronco is starting off with a positive reputation.
I have a 1991 bronco with a 351 winsor efi. It cranks over and pops but won't start. It is getting fuel, spark. Why won't it start? Any help would be greatly appreciated
Thanks, ethan
Old 01-16-2011, 08:48 AM
Encho's Avatar
Encho Encho is offline
The Southernmost Mod
Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.
Check the fuel pressure on the rail, it should be around 39psi, try to pull codes to check what the ECU has to say, there is a lot of other things you could try right now, but that should do for now.
351 m distributor weldworks54 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 11 04-17-2014 08:11 PM
I need the dampner double pulley and the waterpump double pulley Uncle Ethan 1973 - 1979 F-100 & Larger F-Series Trucks 14 11-06-2011 06:04 PM
Car 351 Winsor and Bell housing question.. help vdwightj Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 15 12-09-2004 09:30 AM
Gas Mileage iknowitall 1978 - 1996 Big Bronco 61 10-23-2002 06:00 AM
83 bronco vaccum line diagram help winsor 351 russ10 1978 - 1996 Big Bronco 1 02-16-2001 11:02 AM
Tags
1978, 351, cranks, efi, ford, fuel, gas, pops, spark, start, truck, turns, v8, winsor, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
