85 F250 2wd 460 - Can't get past 80kph - Ford Truck Enthusiasts Forums
Old 01-16-2011, 01:48 AM
Weasal Weasal is offline
Weasal is starting off with a positive reputation.
Just bought the truck...Has 77,000 Km on it...Idles smooth...
Get it on the highway...Get to 80kph...Gets sluggish/Loses power...Step on the gas and it seems worse and starts backfiring...Feather the gas and it will slowly gain speed...
Truck ran perfect (100 kph) first two hours I had it...Then the problem started...
Thoughts?
Old 01-16-2011, 09:16 AM
ArdWrknTrk ArdWrknTrk is online now
pedant
ArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputation
If you mean it backfired out the carb then I'd say your ignition timing has slipped or the ignition box is failing.
Additionally, it only takes one pop to blowout the power valve in the stock 4180 carb.
This will cause it to blubber and run very rich at cruise.
Old 01-16-2011, 11:43 AM
Thanks for the response...Will focus my research in that direction...
If it's in the ignition, wouldn't the problem exists at idle and slower speeds? High RPM like at a shift point?
Blubbering is a good way to describe what's happening...As I let off the gas, it gets to a point where she'll kick in for power then drop off...Too much gas then it drains to the correct level gives the power gain then due to foot not on the gas drops off again...
Looking at the PV...Is there an easy test for that?
Old 01-16-2011, 12:35 PM
pedant
You can have the ignition box tested at most 'Big Box' auto parts stores.
I had made the suggestion before to unscrew it from the fender and place it on top of the engine before driving there in order to make sure it is hot when tested.
They tend to fail when hot and it gives you a chance to examine the potting (plastic sealant) on the underside for signs of melting or boiling.
The ignition timing will need to be checked with a timing light.
This is a basic test and the emissions compliance sticker on the radiator support will have the info. (usually something like 8-10* BTDC at 750rpm with the vacuum advance disconnected and plugged)
I assume the sticker will still be there if you are in Canada... You are reading in Kph?
To see if the powervalve is blown out look down into the primary throttle bore with the engine warmed up and at idle. You should not any raw fuel pouring out of the annular boosters.
If this is the case you will likely have lots of black smoke, fouled plugs and popping on decelleration.
The extra fuel will also cause excessive engine wear by washing any lubricating oil off the cylinder walls, so this should be addressed right away.
This is a start, and my first thoughts on your symptoms.
See if you find the problem. If not then more specific questions and answers will get to the root of it.
It is a simple engine and very reliable.
Old 01-16-2011, 09:08 PM
Went and hauled a load of wood today...Maybe 300 feet of travel...Had the truck warmed up...Forgot to check the power valve as per suggested...Though I never had any black smoke at any time...
I will check it out tomorrow and may post a few pics...Maybe you guys will see something I don't...
Though I did pop open the hood to take a peek at the carb...There was a stamped number in front and what I will assume as an inline filter...
I also had a bit of a stumbling happening as I came through the yard though...It was from moving after a stop (to drop off the chainsaw at my carpentry shop) that it happened...
Not sure if it's related to my problem but I'd rather give too much information than not enough...
Old 01-16-2011, 10:34 PM
Bear 45/70's Avatar
Bear 45/70 Bear 45/70 is offline
Bear 45/70 has a good reputation on FTE.Bear 45/70 has a good reputation on FTE.Bear 45/70 has a good reputation on FTE.
Bad ignition coil.
Old 01-16-2011, 10:43 PM
kermmydog's Avatar
kermmydog kermmydog is offline
kermmydog has a spectacular reputation.kermmydog has a spectacular reputation.kermmydog has a spectacular reputation.kermmydog has a spectacular reputation.kermmydog has a spectacular reputation.kermmydog has a spectacular reputation.kermmydog has a spectacular reputation.kermmydog has a spectacular reputation.kermmydog has a spectacular reputation.kermmydog has a spectacular reputation.kermmydog has a spectacular reputation.
Sounds like you need to check fuel filter, maybe plugs, cap rotor, how old are the wires, check your timing. Other than that all we can do is guess.
Craig
Old 01-17-2011, 10:46 AM
I've only had the truck for less than a month, part of which it was sitting at the garage for a safety...So there still are a lot of unknowns with the truck...
Posting pics of the engine and carb...
Old 01-17-2011, 11:03 AM
pedant
Quote:
Originally Posted by Bear 45/70 View Post
Bad ignition coil.
Could well be, but how does this explain the backfiring and timing being off?
Old 01-17-2011, 02:37 PM
Had the truck running 20 minutes, temp went up to halfway, Took the air breather off and looked down the carb for a few minutes...No gas drops seen...
Old 01-17-2011, 02:45 PM
Bear 45/70's Avatar
Quote:
I did not say it was the only problem, but the speed limited to 80 kph is a classic weak coil issue. The back firing could well be a tune up issue and he should do that anyway, anytime you buy a used vehicle from an individual. Cap, rotor, plugs and wires. Then see what issues the truck still has. I doubt very much this is a carb problem. Timing being off could well be the PO screwed up or the timing chain is bad and it jumped timing, which could cause all his problems and the PO screwed him in that case.
Old 01-17-2011, 03:20 PM
pedant
Bear,
I didn't say that it was a carb problem.
I said that if it had backfired through the carb it would likely blow out the powervalve and that would cause its own set of problems.
(rich running, popping on decelleration and cylinder washdown)
Old 01-17-2011, 04:34 PM
jas88's Avatar
jas88 jas88 is offline
jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.
If it starts to buck and run poorly, and you give it more gas and that makes it worse, that is typically a fuel delivery problem. I am thinking fuel pump or fuel filter.
Old 01-17-2011, 04:57 PM
Bear 45/70's Avatar
Quote:
No, that is typically a weak ignition problem. Fuel delivery problem generally show up close to WOT not while accelerating to WOT.
Old 01-17-2011, 05:49 PM
Would a stuck choke plate be a possible cause?...
I went out to the truck again for another look and the plate was a bit stuck as per the above photo...A little pressure and it now will flip shut and wide open...
I am planning on replacing the spark plugs and wires soon as well as the fuel filter.
Screen default on start up sandbeachprofessor 2015+ F150 6 04-12-2016 03:46 PM
2004 F250 V8 Gas misfire Santa 1 Modular V8 (4.6L, 5.4L) 12 01-10-2014 11:55 AM
1992 F350 no power Arratay 1987 - 1996 F150 & Larger F-Series Trucks 3 11-28-2011 09:34 PM
2008 Ford F250 rattling noise. Kusca 1999 to 2016 Super Duty 5 10-10-2010 11:09 PM
jerking and chunking noise when let off gas saint99 Ranger & B-Series 6 08-23-2005 10:12 PM
Tags
2wd, 4180, 460, 4v, 75l, 85, diesel, f250, feather, firing, ford, gas, loses, order, power
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
