85 F250 2wd 460 - Can't get past 80kph - Page 2 - Ford Truck Enthusiasts Forums
Old 01-17-2011, 08:31 PM
Bear 45/70's Avatar
Bear 45/70 Bear 45/70 is offline
Bear 45/70 has a good reputation on FTE.Bear 45/70 has a good reputation on FTE.Bear 45/70 has a good reputation on FTE.
Quote:
Originally Posted by Weasal View Post
Would a stuck choke plate be a possible cause?...
I went out to the truck again for another look and the plate was a bit stuck as per the above photo...A little pressure and it now will flip shut and wide open...
I am planning on replacing the spark plugs and wires soon as well as the fuel filter.
Not stuck that far open it shouldn't. If it was only open about a 1/4 of the way maybe or if it was stuck closed far enough to cause an idling issue. But it is not causing the backfiring or the missing.
Do a proper tune up, cap rotor, plugs, wires, fuel filters (the one in the carb inlet and the one on the truck frame rail), set the timing correctly and put some Seafoam in the fuel tank. Then see what problems, if any you still have.
Old 01-18-2011, 12:06 PM
jas88's Avatar
jas88 jas88 is offline
jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.
Quote:
No, that is typically a weak ignition problem. Fuel delivery problem generally show up close to WOT not while accelerating to WOT.
This has not been my experience. Pressing down on the accelerator puts more strain on fuel delivery than on the ignition.
Old 01-18-2011, 01:41 PM
Bear 45/70's Avatar
Quote:
Step down on the gas an the fuel already in the carb deals with it, once the float level drops then you would experience a running issue, not immediately. Whereas the ignition has to immediately deal with the richer fuel/air mixture. I get the feeling you are and EFI guy because that is what EFI does as there is no reserve fuel in a float bowl.
Old 01-18-2011, 02:30 PM
jas88's Avatar
I'm 50 YOA and if his fuel pump is weak enough or his fuel filter is plugged enough that the thing is already running poorly just trying to get up to speed, then the float bowl is already almost empty. I've seen considerably more bad fuel pumps/fuel filters than I have bad coils. I don't want to argue with you about this, I just wanted to throw out another possible issue he *might* be having.
Old 01-18-2011, 02:47 PM
Bear 45/70's Avatar
Your logic is flawed. The only way that would show up is if the float level was way low too.
Old 01-18-2011, 02:48 PM
Weasal Weasal is offline
Weasal is starting off with a positive reputation.
I am building a list of parts for the truck...
Recently added is a new ignition keylock... -31 degree weather and I turn the damn key and bent something...I think...
Also on my list is a new fuel pump for the front tank...When I switched tanks last night the truck ran for a bit then started to die out, switched to the back tank and it fired up again...
Course I will be doing items from cheapest to the more expensive...After all I can run on the back tank for a while...
Oh...For the record...I have had no running issues with the truck until I near the 80Kph mark...
Old 05-20-2013, 09:39 PM
Update...
I know it's been while since I've posted on here...Been lurking...
I've also kept the truck on the farm so it hasn't seen much for highway driving...
Took it to pick up some chickens...So was on the highway...Same problem after a few miles...
If I continuously flicked the switch between tanks I got her up past 80 without any more issues...Thoughts?
She has new plugs, wires, cap and rotor and coil...And filters have been changed...
Old 05-21-2013, 08:22 AM
jas88's Avatar
I still say it's fuel or fuel delivery - how old is the gas in the tank?
Old 05-21-2013, 10:33 AM
Tank has been emptied and filled multiple times...
Old 05-21-2013, 10:55 AM
ArdWrknTrk ArdWrknTrk is online now
pedant
ArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputation
But the sludge, rust, swarf... in the tank is still there.
Suction draws it to the in-tank filter (sock) until it restricts the flow to the point you can't maintain speeds above 50 mph.
Switching from one tank to the other allows road vibration and sloshing fuel to uncover the filter and you have better fuel flow.
(At least this is what I get from jas88's post)
Old 05-14-2015, 03:13 PM
Solved
Sorry for not hitting up the site lately...Had the truck parked for a while...The socks were the problem...No foam filter left in them so when the pump kicked it they would starve the pump...$2 filters and it's good to go
Old 05-14-2015, 06:56 PM
cbakker's Avatar
cbakker cbakker is offline
cbakker is starting off with a positive reputation.
Thanks for the update. $2 was the easy part. You forgot the labor charge for the troubleshooting and uninstalling, and installing the tank. Think of what you would have paid for a dealership to do that job. People wonder why they pay so much at the dealership these days.
Sent from my iPad using IB AutoGroup
  #28
Old 05-15-2015, 08:58 AM
jas88's Avatar
Fuel delivery problem. I believe somebody here said that. :-)
Screen default on start up sandbeachprofessor 2015+ F150 6 04-12-2016 04:46 PM
No speeding just only got max 60kph while on "D" any help guys? TroyF250 1999 - 2003 7.3L Power Stroke Diesel 2 11-16-2014 09:41 AM
KPH KPH 1999 to 2016 Super Duty 7 11-05-2014 12:20 PM
2004 F250 V8 Gas misfire Santa 1 Modular V8 (4.6L, 5.4L) 12 01-10-2014 12:55 PM
2008 Ford F250 rattling noise. Kusca 1999 to 2016 Super Duty 5 10-11-2010 12:09 AM
Tags
2wd, 4180, 460, 4v, 75l, 85, diesel, f250, feather, firing, ford, gas, loses, order, power
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
