125,000 Miles. What Should Be Done? - Ford Truck Enthusiasts Forums
1978 - 1996 Big Bronco SPONSORED BY:
Old 01-16-2011, 12:49 AM
DOConnor88's Avatar
DOConnor88 DOConnor88 is offline
DOConnor88 is starting off with a positive reputation.
I have a '96 Bronco with the 5.0. It just rolled over to 125K and I'm wondering what maintenance should be done on it other then the norm (oil+filter, air filter, fuel filter, brakes, trans fluid). Its actually my father's but he works 110 hour weeks so he has little time to devote to it. Trying to help the old man out so any thoughts would be appreciated. This is our 2nd Bronco and shes staying with us till the grave.
Old 01-16-2011, 01:55 AM
greystreak92's Avatar
greystreak92 greystreak92 is offline
greystreak92 has a great reputation on FTE.greystreak92 has a great reputation on FTE.greystreak92 has a great reputation on FTE.greystreak92 has a great reputation on FTE.greystreak92 has a great reputation on FTE.
Transmission should be watched closely... the E4OD has a hard time with high mileage. If you have it serviced or do a fluid and filter, drain the converter as well. The TC's are just as hefty as the transmission itself and a lot of old fluid stays in the converter otherwise. Have a look under the air filter when you replace it. Check for excessive motor oil in the bottom of the box. Its a sign of a dead PCV valve or worse, dying rings and valve seals. If it doesn't see 4WD often make engaging the t-case and the front driveline a monthly habit if only for a few miles.
Old 01-16-2011, 02:07 AM
DOConnor88's Avatar
I've also been noticing that on start up, it sounds and feels like its choking. Not like it needs a battery, alternator, or starter, just like you have to give it some gas. Could this be due to clogged injectors or something else? Im not much of a mechanic but i know a little bit. Thanks a lot for the help btw.
Old 01-16-2011, 07:09 AM
b4hntn b4hntn is offline
b4hntn is gaining momentum as a positive member of FTE.b4hntn is gaining momentum as a positive member of FTE.
Even if no codes are shown for the ECT and the ACT remove them and put them in your oven beside an oven thermometer. Compare resistance reading at different temps to the chart.
Ford Fuel Injection Sensors
Ford Fuel Injection Air Charge Temperature (ACT)
Ford Fuel Injection Engine Coolant Temperature Sensor (ECT)
Old 01-16-2011, 10:02 AM
Encho's Avatar
Encho Encho is offline
The Southernmost Mod
Encho has a brilliant futureEncho has a brilliant futureEncho has a brilliant futureEncho has a brilliant futureEncho has a brilliant futureEncho has a brilliant futureEncho has a brilliant futureEncho has a brilliant futureEncho has a brilliant futureEncho has a brilliant futureEncho has a brilliant future
Yes Connor, it could be clogged injectors.
Old 01-16-2011, 05:01 PM
A dirty IAC (Idle Air Control valve and solenoid) will cause stumbling during cold idle as well. Cleaning is fairly uncomplicated, just be careful not to damage the electrical portion of the assembly.
Old 01-16-2011, 06:24 PM
DOConnor88's Avatar
On top of the maintenance that has to be done, I went to engage the 4wd yesterday and nothing. The dash light comes on and says its in 4wd but nothing. I believe the auto-hubs are to blame as I hear they are infamous for crapping out. The list just gets longer...
Old 01-16-2011, 06:48 PM
Mine came from a travelling saleswoman. Electric push button 4WD had not been engaged in years. I kept pushing buttons a few minutes at a time and the motor finally freed up. Now I try to do it monthly to keep it free.
Old 01-16-2011, 09:31 PM
Encho's Avatar
Hey Grey, which product would you use to clean the IAC?.
Old 01-16-2011, 10:33 PM
Remove it and be prepared to replace the gasket between it and the throttle body.
Cover/seal up the solenoid with a plastic bag and electrical tape.
Using a throttle body cleaner that is safe for sealed or glazed throttle bodies. Regular carb cleaner can destroy the coating that seals the relatively porous metal of the valve body. Clean the valve thoroughly with the cleaner and a small natural bristle brush (a synthetic bristle brush can dissolve in the cleaner).
As to a specific product, one is as good as another in my experience.
Rebirth of an F-250 GMChambers 1987 - 1996 F150 & Larger F-Series Trucks 33 05-05-2014 06:32 PM
Early '04 issues ddetrick78 6.0L Power Stroke Diesel 2 12-03-2012 07:25 AM
1998 4.6 fuel Pressure Issues thosfsull Modular V8 (4.6L, 5.4L) 7 08-29-2010 01:07 PM
Bad Fuel Pump? KU_Bronco 1978 - 1996 Big Bronco 1 08-02-2003 03:32 PM
Over Size Tires Air Presure Billy Bronco 1978 - 1996 Big Bronco 7 05-23-2003 01:49 AM
Tags
125000, f150, ford, good, lot, maintenace, maintenance, maintencance, mile, miles, ranger, service, small, truck, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
