Replacing a broken Shift Tube in the Steering Column (I think!) - Ford Truck Enthusiasts Forums
Old 01-15-2011, 08:46 PM
IrishFitz1 IrishFitz1 is offline
IrishFitz1 is starting off with a positive reputation.
Red face Replacing a broken Shift Tube in the Steering Column (I think!)
I have a 1972 F100 (automatic transmission) that I have been working on and learning from for about a year now. Recently, after starting it at school, it would not go into any gear. I could move the shift handle on the steering column, but the gears were not engaging. It ran fine on the way to school, and it hadn't had any problems recently. I manually put it into gear on the transmission (with the help of a friend) and drove it home. After some investigating, I believe I need to replace the shift tube in the steering column. The linkage to the transmission is fine and changes gears from there. How do I go about replacing the shift tube? Any help would be greatly appreciated!!!
NOTE: I am writing this for my 18 year old son. He loves this web site and uses it often to get direction and guidance when working on his truck. I was recently diagnosed with breast cancer and spend most of my time in bed while doing Chemo treatments, so I had the time to register him and make this post. I am very proud of him and his desire to learn from and work on his truck. It ran 'till warm, but died and wouldn't restart when I gave it to him, and he has it running like a charm now! He has learned how to replace the timing chain, the distibuter, and the ignition module to name a few! Unfortunately, he lacks motivation when it comes to asking for help, so I'm helping him out in that arena. Your comments and suggestions are greatly appreciated! Mom
Old 01-15-2011, 08:49 PM
[quote=IrishFitz1;9830269]
BTW...
Last edited by IrishFitz1; 01-15-2011 at 09:10 PM. Reason: The portion I deleted had already been posted.
Let me tell you a story... FoxFord33 Ranger & B-Series 2 01-21-2017 11:58 PM
4R100 Trans OD light flashing, won't go into 4th, and occasionally over heats Slash19 1999 - 2003 7.3L Power Stroke Diesel 10 04-11-2016 04:15 PM
1965 steering column rebuild fordsforever2015 1961 - 1966 F-100 & Larger F-Series Trucks 6 11-06-2015 06:09 PM
81 F100 3 on tree steering column ? 66_in_ky 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 16 02-09-2015 02:05 PM
The Sad Tale of a C4 Transmission lonelypauly Clutch, Transmission, Differential, Axle & Transfer Case 5 10-02-2012 09:04 AM
Tags
1978, 1994, 2000, automatic, broken, coloumn, f150, ford, ranchero, replace, replacing, shift, shifter, steering, steeringcolumn, transmission, tube
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
